EZNPC Why ARC Raiders Weekly Trials Are Worth the Grind
Добавлено: 04 мар 2026, 07:49
Larry
ARC Raiders Weekly Trials unlock at level 15, resetting Mondays with five rotating objectives where only extracted points count toward ranks, crates, and seasonal cosmetics.
Hitting level 15 in ARC Raiders is where the warm-up ends. The moment Weekly Trials unlock, every run starts to feel like a job interview you can fail in two seconds. If you're trying to keep pace without spending all week farming scraps, a lot of players quietly top up essentials through EZNPC, then focus their actual playtime on the Trials that matter. Because from here on out, it's not "grab loot and vibe." It's "score points, extract clean, don't tilt."
How Trials actually punish mistakes
The board refreshes every Monday with five challenges, and they're usually split between killing specific ARC types and doing practical tasks like opening Probes or finishing data downloads. The scoring isn't hard to understand. It's hard to live with. You can stack a ton of points in a run, then lose it all because you got clipped by a Tick while sprinting to extract. Nothing counts until you're out. That one rule changes how you move, how greedy you get, even how long you stay topside when you're already heavy. The ranks climb fast early, then stall out when everyone else is also optimizing, and that's where the weekly grind turns into a leaderboard fight.
Loadouts that match the rotation
Most weeks, the "right" kit is the one that removes friction. If the Trials lean into flyers like Wasps or Hornets, bring flak and don't try to be clever about it. A Torrente set up for bursts and splash can clear patrols near Buried City Blue Gate before they spiral into a mess. If the board is asking for Bastions or Leapers, stability and control win more than raw damage. A tuned Stitcher feels boring, but boring keeps you alive. Shoot legs when you can, slow them down, and don't chase into open ground just to finish a tag. Dam Battlegrounds tends to give you repeatable fights plus nearby containers, so you can score while you restock and keep the loop going.
Route planning, night raids, and team roles
Night raids are the big swing. Double points sounds amazing, and it is, but the tension goes up because one bad engagement can wipe a whole run's progress. Still, if you can handle low visibility, it's the best way to climb quickly. Squads should play with simple roles: one person pulls aggro and calls targets, the others do the Trial actions fast, then rotate. Don't overcomplicate it. Augments matter more than people admit, too. Anything that speeds looting or interaction time can buy you that last Probe or plant harvest before you pull out. The trick is leaving while you're ahead, not when you feel "done."
Keeping your streak alive
Weekly Trials reward consistency, not hero plays. If you're on a good run, protect it: avoid loud fights you don't need, don't linger after you've hit your point targets, and treat extraction like the real objective. Plenty of solid players fall off the climb because they get stubborn about "one more thing." If you want to stay competitive through the reset-to-reset grind, it also helps to have options ready for rough weeks, whether that's spare gear, a different build path, or even a fresh start via ARC Raiders Accounts when your stash and time are both stretched thin.
Best place to buy ARC Raiders Iteams:ARC Raiders Twitch Drops
