If you have been pushing through the new Echoes of the Void content in Path of Exile 2 and getting that rush from watching whole packs vanish at once, the Lightning Spear Amazon ends up scratching that itch in a way few builds do, especially once you grab a few upgrades from Path of Exile 2 currency without breaking your flow. The build starts modest, sure, but the moment the scaling kicks in, it feels like someone flipped a switch and your character turns into a roaming storm that never really stops humming. The first time the spear chains across an entire room, you get why players keep talking about it. It is simple to play, surprisingly lean on key presses, and weirdly addictive once the rhythm settles in..
The New Frenzy Pace
The 0.3.1 shift to frenzy charges changed things more than people expected. You do not just move faster; you feel your whole kit snap into place. The Amazon’s Revenant’s Call node picks up that momentum and never lets go, almost like the skill starts running on its own once you build a few stacks. Most players hit Frenzy once or fire off Thunderous Roar, then just stand back and watch the Lightning Spear bounce around the screen. The Void Chain support makes those rebounds go wild, so in dense paths or deep Waystones you barely see what you are killing before the damage finishes its sweep. It is messy in the good way, where you stop thinking about single targets and start thinking about how fast you can pull the next pack..
Gear That Actually Matters
Players tend to overcomplicate the gearing path, but the truth is you chase lightning scaling, crit consistency, and anything that speeds up your forks. If a Voidweaver’s Coil drops, grab it. The bonus to fork uptime on shocked enemies feels almost unfair when you see how often it procs. The build does not demand perfect relics to get moving, though; people often get stuck thinking they need a +3 projectile spear before anything works, but even a mid-tier setup clears fast once the support links kick in. The scaling curve just feels smooth, which is rare lately, and it means you upgrade when you want rather than because the build collapses without it..
Late-Game Punch
Once everything is online, the damage ramps hard, and you start hitting numbers that make even bulky void bosses fall over before they get their animations out. It stays fast, flashy, and pretty forgiving even when you push deeper into endgame layers. Just keep your crit path tight and pick up the core lightning clusters on the tree; you will feel the difference right away. And if you want to push the build further without waiting for a lucky drop, grabbing a boost through Path of Exile 2 currency can smooth that climb so you can get straight back to melting everything on screen.
u4gm how to build a lightning spear amazon guide
LunarTinker
