How to Build Loadouts With Pistols in Helldivers 2
Добавлено: 15 сен 2025, 06:09
In Helldivers 2, most players gravitate toward heavy weapons and stratagems when planning their loadouts. However, pistols often get overlooked despite being some of the most reliable sidearms in the game. Whether you are running low on ammo, need a quick swap in tense moments, or want to challenge yourself with more skill-based gameplay, pistols can be surprisingly effective when paired with the right equipment and tactics.
Why Pistols Matter
Pistols in Helldivers 2 are lightweight, quick to draw, and excel in close-quarters combat. They won’t outgun an autocannon or railgun, but they provide consistent fallback damage when your primary is empty. Many veteran players use them as a clutch option in swarm situations or when running solo missions. Because they don’t slow you down, pistols also complement fast, mobile playstyles.
Building a Pistol-Centered Loadout
If you want to lean into pistols as more than just backup weapons, you need to build your entire loadout around mobility and sustain. Here are a few tips:
Armor Choice: Go for lighter armor. Pistols thrive when you can move quickly, reposition often, and avoid getting swarmed.
Stratagems: Pair your pistol with crowd-control options like grenades, sentry turrets, or airstrikes. These let you handle larger groups while keeping your pistol for cleanup.
Perks: Ammo-related perks are essential. Pistols can run dry fast, so anything that improves your ammo economy will keep you going longer.
Team Synergy: If you’re in co-op, coordinate with teammates to cover mid and long-range while you focus on close-range precision.
Recommended Pistols
While different pistols suit different playstyles, some stand out for their stopping power or versatility. A high-damage revolver can drop enemies with fewer shots, while a fast-firing sidearm works better if you prefer speed over raw power. Experiment with different models until you find one that matches your reflexes and rhythm.
When to Invest in Gear
Loadouts are all about balance, and sometimes you’ll want to complement your pistol with extra gear or upgrades. Many players look into ways to optimize their arsenal through additional resources. For example, some guides and communities discuss where to buy helldivers 2 items to speed up progression or test different weapon setups without grinding endlessly. If you’re considering this route, always look for the Best place to buy helldivers 2 items to ensure you’re getting what you need safely and reliably.
Running a pistol-focused loadout in Helldivers 2 is not for everyone, but it adds a fun layer of challenge and variety. With the right armor, perks, and team strategy, pistols can turn into lifesaving tools that keep you alive when the odds are stacked against you. Next time you drop into a mission, consider giving your sidearm more attention—you might be surprised at how powerful it can be when used well.
Why Pistols Matter
Recommended Pistols
