How Does the Ingersoll Rand CD26D GHH RAND Air End Perform?
Добавлено: 25 ноя 2026, 03:42
The Ingersoll Rand CD26D GHH RAND Air End is designed for industrial applications that require reliable, oil-free compressed air and consistent performance. As a double-stage, gear-driven screw compressor block, it is suitable for demanding production environments where air quality and operating stability are important.Get more news about Ingersoll Rand CD26D GHH RAND Air End,you can vist our website!
When selecting an air end, buyers should consider not only technical specifications but also compatibility, maintenance requirements, replacement parts, and after-sales support.
Main Features and Technical Performance
The CD26D uses a double-stage compression design to support high-pressure industrial applications. Its oil-free structure makes it suitable for industries where compressed air quality is particularly important, including food processing, pharmaceutical production, and electronics manufacturing.
According to the manufacturer's published specifications, its main parameters include:
- Maximum power consumption: 376.5 kW (505 hp)
- Maximum volume flow: 49.8 m³/min (1,757 cfm)
- Maximum pressure: 11.5 bar(a) (167 psi)
- Weight: approximately 1,220 kg
These specifications make the CD26D a solution for large industrial compressed-air systems. Actual performance depends on operating conditions and system configuration.
CD26D vs Other GHH RAND Air Ends
Choosing between different GHH RAND models requires understanding the application's pressure and airflow requirements.
The CD14D is a smaller double-stage option, while the CD42D offers greater maximum airflow and power capacity.
Another comparison is the CD26S. Although it shares the CD26 model designation, it uses a single-stage compression design and has a lower maximum pressure of approximately 4.6 bar(a).
Therefore, the CD26D and CD26S are not direct replacements for each other. Buyers should compare operating pressure, airflow, power consumption, and installation requirements before making a decision.
Maintenance and After-Sales Service
Regular maintenance helps extend the service life of an air end and reduce unexpected downtime.
For the Ingersoll Rand CD26D, maintenance should include:
- Inspecting bearings, seals, and lubrication components.
- Checking gear conditions and operating temperatures.
- Monitoring vibration and unusual operating noise.
- Inspecting cooling and moisture separation systems.
- Replacing worn components with compatible parts.
After-sales support is equally important. A reliable supplier should provide model identification assistance, spare parts information, technical guidance, and repair support.
Before purchasing replacement components, confirm the model number, serial number, and part number to avoid compatibility problems.
