Текущее время: 16 фев 2019, 21:48
Часовой пояс: UTC
Начать новую тему Ответить на тему  [ Сообщений: 3 ]
Автор Сообщение
 Заголовок сообщения: 3Dvia Printscreen
СообщениеДобавлено: 08 дек 2013, 20:11
Не в сети
http://yadi.sk/d/Cu06Z1C5DyhDF
3DVIA Printscreen работает как самостоятельное приложение.
Поддерживает OpenGL, Direct3D 8 или Direct3D 9.
Желательно запускать на Win XP
http://yadi.sk/d/GQHvMQp6DyhCE
скрипт для импорта в 3ds max
Скрипт для Blender.
#!BPY
Blender: 249
Group: 'Import'
Tooltip: 'Import 3dxml'
__author__ = "Captain Binky"
__url__ = ("blender","elysiun","Author's homepage, ")
__version__ = "2.0"
__bpydoc__ = ""
import Blender, zipfile, base64, struct, os, sys, time, string
import xml.etree.ElementTree as etree
def load_meshes(filename):
tree = etree.parse(filename)
images = tree.find("//{http://www.3ds.com/xsd/3DXML}ImageSet")
numimages = len(images)
print "ImageSet:", images
imgs = []
imgidxs = []
for i in tree.findall("//{http://www.3ds.com/xsd/3DXML}Material"):
imgidx = i.attrib["texture"]
imgidx = int(imgidx.split(":")[-1])
imgidxs.append(imgidx)
print "Image Idx:", imgidx
allverts = []
for i in tree.findall("//{http://www.3ds.com/xsd/3DXML}Positions"):
verts = unflatten(i.text, float, 3)
allverts.append(verts)
print "NumVerts:", len(verts)
alltxuvs = []
for i in tree.findall("//{http://www.3ds.com/xsd/3DXML}TextureCoordinates"):
uvcos = unflatten(i.text, float, 2)
alltxuvs.append(uvcos)
print "NumUVs:", len(uvcos)
allfaces = []
for i in tree.findall("//{http://www.3ds.com/xsd/3DXML}Faces"):
fdict = i[1].attrib
if "triangles" in fdict:
faces = fdict["triangles"]
faces = string.replace(faces, ",", "")
faces = unflatten(faces, int, 3)
print "NumFaces:", len(faces)
elif "fans" in fdict:
faces = fdict["fans"]
faces = unflatten(faces, int, 4)
print "NumFans:", len(faces)
else:
print "err", fdict
allfaces.append(faces)
objs = zip(allverts, alltxuvs, allfaces)
if len(objs) != len(imgidxs):
print "len(objs) != len(imgidxs)", len(objs), len(imgidxs)
print "Number of objects:", len(objs)
for (objidx,obj) in enumerate(objs):
verts, txuvs, faces = obj
create_mesh(verts, faces, objidx, txuvs, imgs, imgidxs)
def create_mesh(verts, faces, objidx, uvs, imgs, imgidxs):
if len(verts) != len(uvs):
print objidx,
print "len(verts) != len(uvs)", len(verts), len(uvs),
print "resetting the uv list"
uvs = [uvs[0]]*len(verts)
numobjs = len(imgidxs)
size = len(`numobjs`)
objname = str("Mesh-%0"+`size`+"d") % (objidx+1)
mesh = Blender.Mesh.New(objname)
mesh.vertexUV = 1
mesh.verts.extend(verts)
mesh.faces.extend(faces)
for i in range(len(verts)):
mesh.verts[i].uvco = Blender.Mathutils.Vector(uvs[i])
for face in mesh.faces:
face.smooth = 0
#face.image = imgs[imgidxs[objidx]-1]
pervertuv_to_perfaceuv(mesh)
scn = Blender.Scene.GetCurrent()
obj = scn.objects.new(mesh)
obj.sel = True
mesh.remDoubles(0.0)
Blender.Redraw()
def pervertuv_to_perfaceuv(mesh):
face.uv = [vert.uvco for vert in face.verts]
#face.mode |= Blender.Mesh.FaceModes.TWOSIDE
mesh.vertexUV = 0
def unflatten(seq, func, step):
if step == 2: seq = seq.replace(",", "")
seq = seq.split()
seq = list(map(func, seq))
nseq = len(seq)
if step == 2:
return [(seq[i],seq[i+1]) for i in range(0, nseq, step)]
elif step == 3:
return [(seq[i],seq[i+1],seq[i+2]) for i in range(0, nseq, step)]
elif step == 4:
return [(seq[i],seq[i+1],seq[i+2],seq[i+3]) for i in range(0, nseq, step)]
else:
return None
def write_tga(image, numimages):
h = int(image.attrib["height"])
w = int(image.attrib["width"])
fmt = image.attrib["format"]
pixels = image[0].text
size = len(`numimages`)
imgidx = image.attrib["id"]
imgidx = str("Map-%0"+`size`+"d") % int(imgidx)
filename = imgidx + ".tga"
bits = 32 if "A" in fmt else 24
alpha = 8 if "A" in fmt else 0
dirname = "textures"
if not os.path.exists(dirname): os.mkdir(dirname)
pathname = os.path.join(dirname, filename)
if not os.path.exists(pathname):
print "writing %s (%dx%d) %s" % (pathname, w, h, fmt.lower())
with open(pathname, "wb") as file:
file.write(struct.pack("12B", 0, 0, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0))
file.write(struct.pack("HH", w, h))
file.write(struct.pack("BB", bits, alpha))
pixels = base64.b64decode(pixels) #$base64.b64decode(bytes(pixels, "utf-8"))
pixels = rgb_to_bgr(pixels, fmt)
file.write(pixels)
image = Blender.Image.Load(pathname)
image.makeCurrent()
Blender.Window.RedrawAll()
return(image)
def rgb_to_bgr(pixels, fmt):
pixels = list(pixels)
npixels = len(pixels)
step = 4 if "A" in fmt else 3
for i in range(0, npixels, step):
pixels[i],pixels[i+2] = pixels[i+2],pixels[i]
#$pixels = map(chr, pixels)
pixels = "".join(pixels)
#$pixels = bytes(pixels, "latin-1")
return pixels
def read(filename):
time1 = time.time()
path = os.path.dirname(filename)
os.chdir(path)
os.system("cls") if "nt" in os.name else os.system("clear")
print path
if zipfile.is_zipfile(filename):
zf = zipfile.ZipFile(filename, "r")
member = zf.namelist()[1]
filename = zf.open(member)
print "Unzipping", member
time2 = time.time()
print "Total import time is: %.2f seconds." % (time2 - time1)
if __name__=="__main__":
Blender.Window.FileSelector(read, "Import 3dXML", "*.3dxml")
Последний раз редактировалось -=77=- 18 дек 2013, 17:20, всего редактировалось 2 раз(а).
Вернуться к началу
 Профиль
 Заголовок сообщения: Re: 3Dvia Printscreen
СообщениеДобавлено: 08 дек 2013, 20:36
Не в сети
импортер такой комплексный, мне он никогда не нравился, но кроме него ничего нет.
_________________
Вернуться к началу
 Профиль
СообщениеДобавлено: 08 июл 2015, 06:43
Не в сети
Simlab Composer понимает эти 3dxml, экспортит в fbx или dae, но внутренние части и материалы более бредовые названия получают.
Вернуться к началу
 Профиль
Часовой пояс: UTC
Кто сейчас на конференции
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 3
Вы не можете начинать темы
Найти:
Перейти:
Русская поддержка phpBB
