it's work for me and for some of users here, probably blackninja can judje what is wrong, just remember to post your logs after allKamillho писал(а):Still doesn't work. On MP3 too
Kamillho
Well I don't understand why ripper can save textures, but not models ;/Tosyk писал(а):it's work for me and for some of users here, probably blackninja can judje what is wrong, just remember to post your logs after allKamillho писал(а):Still doesn't work. On MP3 too
onelove1210
i & my friend just try to rip Dolphin - Emulator Wii / GC but Ninja Ripper can't rip frame although old version Dxripper can ?
Kamillho
Well. I got Wei model. My friend sent me files. And. actual game pose and broken UV. Still idk why for me doesn't work ;/
will you attach your logs? How many times I need to repeat about logs? 'don't work' words will not help you and don't help us tooKamillho писал(а):Well. I got Wei model. My friend sent me files. And. actual game pose and broken UV. Still idk why for me doesn't work ;/
Kamillho
I forgot, sorry
And I have question. Game must be cracked? Cuz I have original Max Payne 3Ninja Ripper v1.1.0
(c)2004-2012 black_ninja
Fri Oct 26 17:06:24 2012
LOG START
D3D11.DLL loaded
D3D11 Ripper Init
D3D11.D3D11CreateDeviceAndSwapChain() hooked
D3D11.D3D11CreateDevice() hooked
DXGI.CreateDXGIFactory() hooked
DXGI.CreateDXGIFactory1() hooked
D3D11.D3D11CreateDeviceAndSwapChain() ret: 0x00000000
DriverType : D3D_DRIVER_TYPE_UNKNOWN
FeatureLevel: D3D_FEATURE_LEVEL_11_0
ID3D11DeviceContext_Draw hooked
ID3D11DeviceContext_DrawAuto hooked
ID3D11DeviceContext_DrawIndexed hooked
ID3D11DeviceContext_DrawIndexedInstanced hooked
ID3D11DeviceContext_DrawIndexedInstancedIndirect hooked
ID3D11DeviceContext_DrawInstanced hooked
ID3D11DeviceContext_PSSetShaderResources hooked
ID3D11Device_CreateInputLayout hooked
D3D11.D3D11CreateDevice() ret: 0x00000000
D3D11 Ripper Uninit
LOG END
Fri Oct 26 17:09:01 2012
Kamillho
Licenced games has protection that can lock work of ripper.
May be wrapper mode will work
Kamillho
Still doesn't work with MP3
And with Sleeping DogsNinja Ripper v1.1.0
Sun Oct 28 9:59:46 2012
LOG START
D3D9 Ripper Init
D3D9.Direct3DCreate9() hooked
D3D11.DLL loaded
D3D11 Ripper Init
D3D11.D3D11CreateDeviceAndSwapChain() ret: 0x00000001
D3D11.D3D11CreateDevice() ret: 0x00000001
IDXGIFactory_CreateSwapChain hooked
DriverType : D3D_DRIVER_TYPE_HARDWARE
IDXGIFactory_CreateSwapChain()
IDXGISwapChain_Present hooked
CreateProcessW( "C:\Program Files (x86)\Rockstar Games\Social Club\wow_helper.exe" 0x1af0 0xe0000 ) ret: 0x00000001
CreateProcessW( "C:\Program Files (x86)\Rockstar Games\Social Club\wow_helper.exe" 0x580 0xa0000 ) ret: 0x00000001
D3D9 Ripper Uninit
D3D11 Ripper Uninit
LOG END
Sun Oct 28 10:00:25 2012
And...how import Need For Speed The Run models with perfect UV? I don't understand tutorial on site...Ninja Ripper v1.1.0
Sun Oct 28 10:01:53 2012
LOG START
D3D11.DLL loaded
D3D11 Ripper Init
D3D11 Ripper Uninit
LOG END
Sun Oct 28 10:02:19 2012
wich part you did not understand?Kamillho писал(а):And...how import Need For Speed The Run models with perfect UV? I don't understand tutorial on site...
you just change 6-7 numbers to 7-8 and then 8-9 manually till you get correct uv
