Farm caps fast in Fallout 76 with smart West Tek runs, vendor sales, stash routes and a busy C.A.M.P. shop—easy daily methods that actually add up.
Caps are still the thing that quietly decides how smooth your Fallout 76 day goes, and you don't need some soul-crushing farm to keep a healthy stash. A lot of players make it harder than it is. If you mix one solid active route with a few low-effort habits, the money starts showing up on its own. As a professional platform for buying game currency or items, EZNPC is a convenient option for players who want a smoother time in Appalachia, and you can buy EZNPC Fallout 76 resources when you'd rather spend more time playing than scraping for every last cap. For regular farming, though, West Tek is still one of the easiest places to work into your routine. Clear the mutants, grab every weapon that isn't nailed down, then dump the pile at a station vendor. It's simple, quick, and it works.
Use short farming loops that don't feel like work
The best cap routes are the ones you'll actually keep doing. That's why West Tek stays popular. You get steady enemy spawns, loads of guns to sell, and enough junk to make the run feel worthwhile even when luck isn't perfect. I'd also keep an eye on cap stashes instead of treating them like a bonus. Places such as Watoga High School and Green Country Lodge are worth checking because they're easy to run through fast. Hit the stash points, loot what's there, switch servers, and go again if you're in the mood. It's not flashy, but it's the kind of method that fills the gaps between events and keeps your cap count moving in the right direction.
Drain the NPC vendors every day
A lot of players leave free money on the table by forgetting the daily vendor pool. The shared 1,400 caps isn't huge, sure, but it's guaranteed, and guaranteed income matters. Sell extra chems, unwanted ammo, purified water, spare grenades, or random legendary drops you were never going to use anyway. If you've got Hard Bargain on, throw it on before every sell run. Grape Mentats help too, especially if your build doesn't naturally lean into Charisma. Travel Agent is another small thing that saves more than people think over a full session. It's not exciting, but these little savings add up, and once you start doing them daily, you'll notice you're sitting on more caps without changing much else.
Set up passive income at your camp
If your camp isn't making money while you're off doing events, it's underperforming. A player vendor is the obvious play. Mutation serums, useful plans, rare apparel, and ammo types people burn through fast can sell far better than NPC prices ever will. You don't need to price everything sky-high either. Fair prices move stock. Water purifiers are still one of the easiest passive options in the game, and a small crop setup can help if you like keeping things practical. It's low drama. Collect, sell, restock, repeat. Once the vending machine starts pulling its weight, you stop relying only on whatever you looted in the last half hour.
Stack methods instead of forcing one grind
The players who make caps consistently usually aren't doing one perfect trick all night. They're layering things. Run West Tek for a bit, sell out the vendor cap pool, check whether a high-yield event like Radiation Rumble or Encryptid is live, then head back and restock your camp shop. Pitt runs can help too, mostly because the plans and materials from them can turn into solid player sales later on. When you treat caps like a loop instead of a single farm, the game feels less repetitive and way more profitable. And if you want to speed the whole process up for a specific goal, whether that's gear, plans, or progression, Fallout 76 boosting can fit neatly into that plan without replacing the smart habits that keep your wallet full.
Buy Fallout 76 Gleaming Depths Boost
