EZNPC Flygon ex B3 Deck Guide Strategy Combos Counters
Larry
#1 Сообщение Larry »
Flygon ex is a patient control deck that wins with steady chip damage, smart switching, and long-game pressure, turning damaged Bench targets into easy prizes with Cyrus.
Flygon ex from B3 plays a very different game from the usual rush decks. It's not built to blow through prizes on turn two. It wants time, space, and a board that stays intact long enough for the pressure to snowball. If you're the kind of player who likes squeezing value out of every turn, this deck has a lot going for it, and plenty of players who keep up with deckbuilding tools or pickup options through EZNPC tend to like lists like this because the plan is clear even if the games get messy. Once Flygon ex is active, the real appeal shows up fast: steady damage on the Active, extra strain on the Bench, and a constant feeling that your opponent is slowly running out of safe places to hide.
Getting set up the right way
The early turns matter more than people think. A lot of newer players panic and swing with whatever they have, but Flygon ex usually rewards patience. You're trying to evolve cleanly, attach the right mix of Energy, and avoid giving away cheap knockouts before your main attacker is ready. Trapinch into Vibrava into Flygon ex should be your first priority, plain and simple. Cards like Poké Ball, Copycat, and Mesagoza help smooth that out, but you still need to respect the deck's slower pace. It doesn't have a built-in shortcut. So don't pretend it does. If your first few turns look quiet, that's often fine, as long as your board is moving toward one strong mid-game position.
Where the pressure really comes from
Sand Slammer is what makes the deck worth playing. The attack doesn't always look scary on paper, yet in real games it changes everything. Chip damage builds up in awkward places. Benched Pokémon that seemed safe suddenly become liabilities. That's where Cyrus becomes nasty. You soften something up, pull it forward, and take a knockout your opponent probably thought they had another turn to protect. Rocky Helmet adds even more strain, especially against players who are forced to keep swinging into Flygon ex just to stay in the game. And because Flygon ex often sits Active for several turns, healing matters a lot more than it would in a faster shell. Lillie and Lucky Ice Pop can buy exactly the extra turn you need, and with this deck, one extra turn can feel huge.
Matchups and common mistakes
The rough matchups are pretty easy to spot. Fast decks can punish you before the engine starts rolling, and Energy disruption is a real headache because Flygon ex needs both the right setup and enough time to use it. If the opponent keeps dragging it out of the Active Spot or sniping your evolve line before it settles in, the whole plan gets clunky. That said, plenty of Flygon ex losses come from self-inflicted mistakes. People overbench. They attach carelessly. They chase damage too early instead of protecting the line that actually wins the game. This deck isn't flashy, but it is demanding. You've got to think a turn ahead, sometimes two, and accept that you're not playing for instant rewards.
How Flygon ex actually closes games
The best Flygon ex games don't usually look explosive. They feel tight, annoying, and gradually tilted in your favour. You keep the Active spot locked down, keep spreading damage, and force your opponent into bad trades they can't fully avoid. That's why the deck shines most against slower boards that need time to develop. If you pilot it with discipline, the Bench turns into a pile of future prizes rather than backup attackers, and smart players who track evolving lists or browse Pokemon TCG Pocket Cards will probably recognise why this strategy sticks around: it doesn't need a huge burst turn to win, just enough control to make every turn count.
Buy [Global]Poke Gold*30+pack Hourglass*1800+wonder Hourglass*2000+total
