The Guardian High Commander Orb in Aion 2 is a Heroic-tier item designed for Elementalists. Most players encounter it around level 45, and it has an item level of 108. In this guide, we’ll break down the key questions players usually have about this item, explain how it works in practice, and give tips on maximizing its potential.
What is the Guardian High Commander Orb?
The Guardian High Commander Orb is a Heroic Orb that serves as a primary weapon for Elementalists. Its main appeal is its high attack range, multiple stat bonuses, and several utility slots that allow for customization through Magic Stones and Divine Stones.
Equip Level: 45
Item Level: 108
Race/Class: Elementalist only
Max Enchant: +20
Max Exceed: 5
In general, most players aim to upgrade this orb to increase their combat efficiency, particularly in PvP situations or high-level dungeons.
What Stats Does It Offer?
One of the main reasons players pursue this orb is for its well-rounded stats. Here's a breakdown:
Attack: 327 ~ 654
Accuracy: 50
Critical Hit: 150
PvP Damage Boost: 10%
Magic Stone Slots: 5
Divine Stone Engraving Slots: 1
The orb also enhances several combat stats through its soul imprint abilities:
Might: 81 ~ 100
Precision: 81 ~ 100
Attack: 32 ~ 44
Accuracy: 68 ~ 85
Critical Hit: 37 ~ 50
HP: 306 ~ 359
MP: 153 ~ 183
Combat Speed: 13.8% ~ 15.9%
Status Effect Chance: 23% ~ 26.5%
Multi-hit Chance: 9.8% ~ 11.3%
Critical Attack: 52 ~ 67
Back Attack: 52 ~ 67
Block: 57 ~ 73
Weapon Damage Boost: 14.9% ~ 17.2%
Most players find that this combination allows for strong burst damage in PvP while maintaining utility in PvE scenarios.
How Do You Obtain It?
The Guardian High Commander Orb can be obtained from the Trade Shop. In general, players usually either earn the currency needed through dungeon runs or trade resources accumulated from quests. One practical tip: check for offers or availability in the in-game trade system regularly, as this can sometimes save time.
Additionally, some players search online for offers to acquire it faster. For example, listings of Aion 2 items for sale at U4N are often cited as a convenient way to get rare Heroic items, though you should always verify legitimacy before making any transactions.
How Do Soul Imprints Work?
When the orb is initially imprinted with a soul, it gains 5 additional abilities. Most players prioritize these imprints to maximize both offensive and defensive potential:
Boosted Might and Precision – Improves overall attack effectiveness.
Increased Critical Hit Rate – Particularly important in PvP.
Enhanced Multi-hit Chance – Makes elemental skills more reliable.
Improved Combat Speed – Allows for faster spellcasting and rotations.
Additional HP/MP – Gives Elementalists better survivability in longer fights.
In practice, this makes the orb more than just a raw damage weapon; it becomes a versatile tool for controlling fights and mitigating risk.
Can It Be Enhanced?
Yes, most players aim to enchant the Guardian High Commander Orb to the maximum of +20. Beyond enchantment, the orb can also exceed 5 times, which further increases its base stats. Combining these upgrades with carefully selected Magic Stones and Divine Stone engravings usually results in a high-performing weapon capable of handling both solo and group content.
Enchanting: Improves base attack and main stats.
Exceeding: Enhances overall combat effectiveness.
Magic Stones: Usually chosen based on preferred elemental damage or status effects.
Divine Stone: Offers a minor but strategic bonus; many players engrave for critical hit or PvP damage.
Most experienced Elementalists recommend prioritizing enchanting first, then slotting stones that complement your usual playstyle.
Appearance and Flavor
The orb’s visual design, called Tranquil Moon, is relatively understated but elegant. Many players appreciate that it doesn’t visually clash with other gear, allowing for a clean, thematic appearance on screen.
Is It Worth the Investment?
In general, most players consider the Guardian High Commander Orb worth pursuing because:
It offers a strong combination of attack and utility stats.
It’s highly customizable through enchantments, exceeding, and stone slots.
It supports both PvP and PvE play effectively.
That said, players usually balance their investment in this orb against other gear upgrades, especially if they’re aiming for endgame content. The orb is most impactful when fully upgraded and properly imprinted with a soul.
Practical Tips
Track Market Offers: Keep an eye on trade shops or listings of Aion 2 items for sale at U4N to see if you can acquire the orb efficiently.
Prioritize Imprints: The 5 additional abilities from the soul imprint significantly change how the orb performs. Focus on stats that fit your playstyle.
Max Out Enhancements: Enchanting and exceeding the orb will provide the most noticeable improvements.
Stone Slots Matter: Magic and Divine Stones allow fine-tuning for specific fights, so don’t ignore them.
Most players find that combining these approaches results in a weapon that can handle everything from regular dungeons to competitive PvP encounters.
The Guardian High Commander Orb is a solid choice for any Elementalist looking to balance damage, survivability, and utility. Its combination of raw stats, soul imprint abilities, and customizable slots makes it versatile for both casual and hardcore players. By following common practices like prioritizing enhancements, carefully selecting stones, and checking trade opportunities, you can make the most out of this Heroic-tier item.
Where to Get Aion 2 Guardian High Commander Orb and How to Upgrade It
IndigoSonata
