How to Complete Main Quests Fast in Aion 2
Добавлено: 09 дек 2025, 01:17
lonevessel
If you’ve just landed in Aion 2 and want to speed through the main quests, you’re definitely not alone. The game throws a lot at you early on, and while most quests are straightforward, there are plenty of small tricks that can help you clear them much faster. After going through the story on different characters, I’ve found some easy habits and time-saving tips that make a big difference, especially for players who want to level efficiently without getting stuck in side distractions.
Below is a full guide based on hands-on experience, written in a simple, friendly way so anyone can follow along. Whether you’re a casual player or someone who just wants to get strong quickly, these tips should help you breeze through the main storyline.
Focus on Zones With the Best Experience Flow
Aion 2’s zones are designed so you rarely need to grind or run back and forth for too long. Still, some areas have denser quest hubs that naturally save time. When you move into a new region, don’t instantly sprint toward random side objectives. Instead, check the map markers carefully and follow the main quest’s path first. It usually leads you through monster-dense corridors where you can complete multiple objectives at once.
One thing that helped me a lot was keeping my resource plan tight. As you progress, your character's growth depends heavily on gear upgrades and a steady flow of Aion 2 Kinah, especially when repairing equipment or enhancing early weapons. Managing your gold early prevents unnecessary downtime later, which keeps your questing fast and smooth.
Use Auto-Pathing Wisely, Not Blindly
Aion 2 includes auto-pathing for most quest objectives, which feels super convenient. However, following it blindly sometimes leads you into crowded spots or long detours. Whenever you’re sent to defeat enemies, look around before engaging. Most maps have small clusters of mobs just off the auto-route where you can clear the objective much faster than fighting in the main group with other players.
Auto-pathing is best for traveling long distances or returning to NPCs. For combat quests, manual control almost always beats it. Once you get used to switching between both, your quest time drops noticeably.
Upgrade Gear Gradually to Avoid Getting Stuck
You don’t need endgame-level gear to finish the early main quests, but upgrading a little at each stage makes combat noticeably faster. Focus on your main weapon first; even green-quality upgrades can make your quests smoother.
And if you’re the type who likes jumping ahead of the curve, some players choose to buy Aion 2 Kinah from third-party markets, though this isn’t required at all. Personally, I prefer earning resources through normal gameplay, but I know some players like having a boost early. Just make sure to stay within the game’s rules and keep your account safe.
Take Advantage of Mobility Skills and Mounts
Aion 2 gives you mobility skills fairly early, but many players forget to use them while questing. Skills that leap or dash can shave precious seconds off your route every time you travel between objectives. When you multiply that across hundreds of quests, it saves a ton of time.
Mounts are another huge time-saver. Always summon yours when traveling across open maps. It sounds obvious, but you’d be surprised how many players forget to use it after dismounting in combat.
Group Up for Boss Fights or Tight Areas
Most main story bosses are manageable solo, but some of them become much easier if you team up with nearby players for a few minutes. The game is still new, so zones are usually populated; using quick invites or just helping each other naturally can speed things up.
When you reach storyline segments that require killing elite monsters or clearing heavily contested areas, grouping is almost always faster and safer. You won’t need to waste time waiting for respawns or running back after dying.
Save Consumables for Harder Chapters
A lot of players use potions and buffs too early. Try to save your stronger attack boosts for chapters where mobs are tankier or where you need to fight mini-bosses one after another. Keeping a small stockpile lets you burst through tough quests without slowing down.
Some players also like stocking consumables through trading or community sources. If you're dealing with in-game markets, platforms like U4GM are frequently mentioned by veteran players, though you should always do your own research and choose whatever feels comfortable and safe for you.
Don’t Ignore Side Systems That Boost Quest Speed
While the main quests are your priority, a few optional systems can indirectly help you complete them faster:
Companions can add extra damage, making clears quicker.
Basic crafting helps you keep potions stocked.
Wing upgrades (once unlocked) drastically improve travel efficiency.
You don’t need to max everything; just keep the essentials updated enough to support your questing pace.
Know When to Move On
Sometimes you’ll run into story quests that ask you to reach a certain level. If that happens, don’t wander aimlessly. Instead, do a few high-efficiency side quests or daily tasks. Some of these give surprisingly good experience, letting you return to the main quest within minutes.
Avoid grinding normal monsters unless absolutely necessary. Quest XP is almost always better.
FAQ
1. What’s the fastest way to earn resources for early upgrades?
Doing main quests and daily missions gives you a steady income. Selling unwanted drops also helps a lot.
2. Is Kinah hard to earn at the start?
Not really. Early quests reward enough for upgrades and repairs. Just avoid overspending on unnecessary items.
3. Can Kinah be traded with other players?
This depends on the game’s current trade limitations. Some servers have restrictions to prevent abuse, so always check in-game rules.
4. Are gear upgrades expensive?
Low-tier upgrades are fairly cheap, but costs rise later. It’s best to upgrade slowly and avoid rushing enhancement levels you don’t need yet.
5. Are rare items needed to finish the main story?
No. You can finish all main quests with mid-tier gear as long as you stay upgraded consistently.
6. Do main quests reset or change during events?
Main quests stay the same, but events sometimes add temporary bonuses that make leveling faster.
7. Should beginners follow guides or learn on their own first?
Guides help you avoid common mistakes, but exploring the game yourself is totally fine. The story is pretty easy to follow.
8. Are third-party markets safe to use?
Always be cautious. If you decide to use any external platform for game items or currency, make sure it’s known, reputable, and doesn’t violate game rules.
Recommended Loadout: New Player Guide: How to Build Wealth and Farm Kinah in Aion 2
