Japan changes the way you think about car choice. A flashy build can look great on the festival menu, then feel slow once you hit tight roads and quick elevation changes. That is why I'd start by locking in one sensible base car from FH6 Cars instead of blowing credits on something that only works in a straight line. In the early hours, grip, balance, and easy recovery matter more than bragging rights, and a solid all-wheel-drive setup usually saves you from a lot of bad spending.
Driving settings
Credit flow
Touge and barn finds
Tune the basics before the first big run
Most of the slowdown comes from settings people never touch. Braking line only is a better call than the full line because it gives you room to learn proper turn-in points. Performance mode helps with input feel, and it does show up in close fights. Keep radar on, since side-by-side racing in narrow sections gets messy fast.
SettingPickWhy it helps
Driving lineBraking onlyLess hand-holding, cleaner corner entry
Traction controlOffBetter exits once you can manage throttle
Stability controlOffLets the car rotate in hairpins
Graphics modePerformanceSharper response in quick transitions
That mix is simple, but it works. You stop fighting the game and start learning the road.
Spend credits like you mean it
The economy in Horizon punishes impulse buys more than most players expect. A garage full of dream cars sounds fun, yet it can leave you short on the one thing that actually keeps progress moving. Early on, one versatile car is enough. Mid-game, add a dirt car and a road car only when you have a real event reason. After that, upgrades should go to builds you already trust. If a car cannot win often, it is not a bargain, no matter how cool it looks in the showcase.
Use touge runs and barn finds to build momentum
Touge racing is where all the small stuff shows up. Exit speed matters more than top speed, and good braking beats raw power on these roads every time. Barn finds work in a similar way. They do not just pop because you wandered around for five minutes. You will usually unlock more by clearing regional events, pushing festival progress, and revisiting rural areas after the map opens up a bit more. That is also where smart FH6 Credits management starts to pay off, because the player who saves for the right car gets back on the road faster and wastes less time rebuilding a weak garage. Keep the loop tight, keep the car list lean, and the whole game feels smoother.
Where to Optimize FH Cars and Credits with u4gm
CrystalVibe
