EZNPC How to Farm Light Gun Parts Fast in ARC Raiders
Larry
#1 Сообщение Larry »
Farm Light Gun Parts in ARC Raiders by looping suburban scout zones, low-security sites, and drone patrol events; run a fast, quiet kit, tag parts, stash often, and keep upgrades rolling.
Light Gun Parts always seem to vanish the moment you've finally got a build that feels good. One minute you're tweaking a mid-game mobility setup, the next you're staring at a repair screen with nothing to feed it. I used to just roam and hope, and yeah, that's a slow way to lose patience. If you're short on time, a lot of players will top up their essentials through EZNPC, since it's built around grabbing game items and currency without turning your evening into a scavenger sim. Still, if you want to farm in-game and keep your stash steady, it starts with hunting the right enemies and the right events, not the biggest thing you can find.
Target The Right Fights
Here's the trick: heavy units look tempting, but they're usually not the best return for Light Gun Parts. You'll have better luck bullying the nimble scouts and support drones that show up around suburban edges, low-security facilities, and those messy in-between zones people sprint through. Watch for supply cache defenses and convoy interruptions, because lighter enemies tend to roll in waves there. You're not chasing a heroic kill. You're looking for repeatable spawns, quick looting windows, and enough bodies on the ground that the parts drop before you're forced to reset.
Build For Speed, Not Pride
Your loadout shouldn't be "cool," it should be fast. High fire-rate guns, something that pierces, anything that lets you delete a cluster before they scatter. If you're taking ages on each wave, you're basically paying a time tax for every drop. Bring one gadget that stops movement—stun, tether, whatever you've got—because flankers are what drain your meds while you're staring at loot. Mobility gear matters more than people admit. Grapple, dash booster, even a setup that lets you vault and reposition cleanly. Solo players can shave minutes by going quiet, too. A suppressed weapon and a patient angle can let you pick the high-value targets without waking up the whole block.
Squad Roles And A Real Route
If you're running with a squad, don't do that thing where everyone shoots, everyone loots, and nobody watches the clock. Split it up: 1) one person locks down waves with traps or area denial, 2) one person tags threats and deletes anything that's about to rush, 3) one person is the dedicated looter who actually checks side rooms and weird corners. Then plan a loop, not a straight line. Hit three to five dense spots, use vehicles or fast travel to skip dead space, and bail before reinforcements stack into a full-on slog. Keep your bag clean, too—mark the parts as soon as they drop, ditch low-tier clutter, and don't be the player who finds a stack and can't pick it up. If you're also watching for bonuses while you farm, it's worth checking ARC Raiders Redeem Codes mid-session so you can stack any freebies into the same run without breaking your pace.
Buy ARC Raiders Accounts Accepted-EZNPC.com
