Learn how to use Orbs of Chance in Path of Exile 2, which bases are worth gambling on, and why smart players save them for valuable, chanceable uniques.
The Orb of Chance in Path of Exile 2 has that nasty little pull that every loot game needs. You look at a plain white base, hover the orb over it, and think, “Maybe this one.” Most of the time, it isn't. That's the deal. Still, when you're short on currency or hunting specific gear, places like EZNPC can help players buy game currency or items without spending every spare hour farming scraps. The gamble itself, though, is hard to replace. One click can do nothing, or it can turn a dull base into something your whole build suddenly cares about.
Start With the Right Base
You can't just pick up any random item and expect magic. The item needs to be normal rarity, with no mods on it. White text, clean base, nothing fancy. That's what the Orb of Chance works on. The important bit is whether that base actually has a unique version available through the regular drop pool. If the unique only comes from a boss, a league mechanic, or some special encounter, chancing it won't work. People waste piles of orbs this way. It feels awful, because the mistake isn't bad luck. It's just bad information. Check the base first, then start clicking.
Don't Chance Trash Just Because You Can
There's a big difference between having fun and throwing currency into a hole. If the unique version of a base sells for nothing, why bother? Smart players usually aim at bases tied to strong meta items. Heavy Belts are a classic sort of target when the right unique exists. Certain rings, shields, or weapon bases can also be worth a shot, depending on the market and the current builds people are playing. The value changes, too. Something ignored one week can jump in price after a balance change or a streamer build takes off. So don't work from old habits only. Have a quick look at trade prices before filling a stash tab.
Batch Chancing Feels Better
Doing this one item at a time is painful. You pick up a base, use one orb, sigh, move on. It kills the mood fast. A better way is to collect a full tab of the exact base you want, then run through them in one sitting. It's cleaner, quicker, and honestly a bit more exciting. You see the failures fly past, but you also know every click has the same tiny shot. Keep a few extra stash tabs if you can. Sort the bases properly. Don't mix in the wrong item level or the wrong base type because you were rushing after a map.
Know When to Stop
Chance Orbs are fun because they promise something silly and huge, but they're still a gamble. If you're breaking down unwanted uniques for shards, trading for more orbs, or stocking up on POE 2 iteams to support a bigger project, set a limit before you begin. Maybe it's two stacks. Maybe it's one stash tab. Once you hit that line, walk away for a while. The best chancing sessions are the ones where you understand the risk and still enjoy the click. If the orange text shows up, great. If not, at least you didn't burn your whole league budget chasing a ghost.
Buy PoE 2 Atlas Passive Tree Boosting
