U4N: How to Unlock More Car Slots in Forza Horizon 6
lonevessel
#1 Сообщение lonevessel »
The release of Forza Horizon 6 takes players into the neon-drenched streets of Tokyo and the sweeping mountain roads of Japan. With a massive day-one launch roster of 618 cars, managing your collection is a massive part of the experience.
However, if you've been spending time customizing your in-game houses, you might have run into a frustrating wall: your default garage layout caps you at displaying just 3 cars plus your currently active vehicle. If you want to show off more of your fleet at once, you have to actively unlock more car slots.
The House Perk Strategy: Hakusan and Vision House
To expand your display capacity, you need to target specific real estate in the game. You can’t just buy any random house and expect your garage capacity to grow automatically. The magic lies in a specific perk called the "Additional Garage Slot."
Two major properties carry this perk, and buying them is the foundation of expanding your slots:
Hakusan Mountain Lodge: This should be your first target. Purchasing this property unlocks your first additional slot.
Vision House: A high-end property available later in your playthrough. Snagging this one adds another slot to your pool.
The Numbers Behind the Unlock
Unlocking these houses requires millions of in-game Credits (CR). For instance, saving up for premium properties like the Vision House often requires grinding out high-paying seasonal championships or flipping rare Wheelspin cars on the Auction House. If you don't have the time to grind 30-40 hours just to hoard currency, you can use specialized marketplaces like U4N to quickly get enough credits or directly buy FH6 cars that are otherwise locked behind steep progression walls. This lets you bypass the repetitive credit farm and focus straight on building up your properties.
Step-by-Step: How to Manually Place Your New Car Slots
Here is the trick that catches most players off guard: owning the houses unlocks the ability to have more slots, but it does not automatically place them. If you buy Hakusan Mountain Lodge and just walk into the garage, you will still only see your original 3 cars.
You have to use the built-in customizable garage tools to manually drop a new locator marker. Here is exactly how to do it without getting lost in the menus:
1.Fast Travel to the Specific Property:Requires property ownership.
Open your map and fast travel directly to the house you just bought (like Hakusan Mountain Lodge). The extra slot perk applies strictly to the specific garage structure of the house it was unlocked from.
2.Enter the Customizable Garage Tab:From the main menu.
Once inside the house, pull up your main menu. Navigate over to the Customizable Garage tab and click on Customize Garage to switch into the free-cam edit mode.
3.Buy a Car Display Locator:Prop Menu.
Open the prop library/object menu within the editor. Look for the item labeled Car Display Locators. Because you own the property and have the perk active, you will now see that you have permission to purchase an additional locator.
4.Place and Save:Free-cam placement.
Move the free-cam around your garage floor and place the new locator down wherever you want your extra car to park. Make sure it isn't clipping into walls or other props. Save your layout and exit the builder.
5.Assign a Vehicle:Final step.
Go to your Display Cars menu option. Select the newly placed slot, browse your garage roster, and assign the vehicle you want to showcase.
Keep in Mind: Garage limits are tied to hardware and engine optimization to keep performance smooth while rendering highly detailed 3D car models. Even with all properties completely unlocked, the maximum allowed setup in a single garage space is capped at 3 default slots plus your current car, augmented by the specific house perks you manually activate.
By targeting the right houses, banking the necessary credits, and using the edit mode to physically place your locators, you can transform a basic garage into a custom showroom that properly reflects your journey through Horizon's Japanese festival.
