The crossbow in Helldivers 2 is one of those weapons that feels unusual at first but quickly proves its worth in the right hands. Unlike traditional rifles or explosive launchers, the crossbow focuses on precision and timing, rewarding players who know when and where to strike. If you are looking to diversify your arsenal or challenge yourself with a different combat style, the crossbow is a solid choice.
Why Choose the Crossbow
The crossbow deals significant damage to medium-armored enemies and is surprisingly effective in stealthier approaches. While it doesn’t match the raw destructive power of heavier stratagems, it provides a reliable way to handle specific threats without drawing too much attention. Another advantage is its ammo efficiency. Compared to high-consumption weapons, you can carry enough bolts to stay useful for longer missions.
Best Situations to Use It
The crossbow shines in missions where enemy patrols are frequent but not overwhelming. For example, against bugs or lightly armored automatons, a well-placed bolt can eliminate threats before they alert the horde. It is less effective when swarmed, so make sure to pair it with a sidearm or coordinate with teammates who can provide crowd control.
Tips for Getting the Most Out of It
Aim for weak points. The crossbow rewards accuracy more than spray-and-pray weapons.
Stay mobile. Reloading can leave you exposed, so move strategically between shots.
Combine with stratagems. Use mines, turrets, or support weapons to cover the gaps when enemies close in.
Play in co-op. The crossbow works best when teammates handle heavy firepower, letting you pick off key targets.
Building Your Loadout
If you want to experiment with crossbow-focused gameplay, consider balancing your loadout with supportive stratagems. While some players prefer explosives as a backup, others use defensive tools like supply packs to ensure they never run dry. When customizing your build, remember that investing in resources can also make a big difference. Many players choose to buy Helldivers 2 items to quickly unlock or optimize their setups, while others prefer to grind for upgrades. Similarly, those who want faster access to premium cosmetics or time-saving boosts sometimes buy Helldivers 2 super credits to complement their progress.
Final Thoughts
The crossbow in Helldivers 2 may not be the flashiest weapon, but it adds a refreshing layer of strategy and precision to your missions. It is a weapon that rewards patience, positioning, and teamwork. If you enjoy weapons that require skill rather than brute force, mastering the crossbow can be a satisfying way to enhance your experience on the battlefield.
How to Use Crossbow in Helldivers 2
