Elden Ring has always been known for its brutal challenge and intricate combat mechanics. But what if you could mix it up with a unique twist? Enter the Ghost of Tsushima mod, which brings a powerful new moveset to Elden Ring, allowing you to play as Miyamoto Musashi with his famous sword styles. Whether you’re a diehard Elden Ring veteran or a fan of Ghost of Tsushima, this mod offers a thrilling new experience. In this guide, I’ll walk you through my experience with the mod, share some tips, and discuss how it performs in the New Game Plus 8 difficulty.
Getting Started with the Musashi Moveset Mod
The first thing to note is that this mod is inspired by the Ghost of Tsushima combat style. If you’ve ever played the latter, you’ll immediately recognize the fluid, martial arts-inspired moves. With both one-sword and two-sword styles available, the mod allows for a lot of flexibility in your approach to combat.
When you first equip the moveset, you'll notice the powerful yet slow strikes that make you feel like an unstoppable force. However, there’s a trade-off: while the damage potential is high, the attack speed is much slower than what you might be used to in Elden Ring’s base combat. It’s a great way to feel like Musashi himself, but it requires patience and precise timing. If you’re someone who prefers faster-paced action, this might take a bit of getting used to.
One Sword Style vs. Two Sword Style
Let’s break down the two sword styles.
One Sword Style
Starting with the one-sword style, you’ll notice that Musashi’s single sword attacks feel impactful, but the damage output can be a bit underwhelming, especially if you're tackling higher difficulties. In New Game Plus 8, for example, the damage isn’t as high as some of the more broken weapons, like the Rivers of Blood katana. That said, this style excels in elegance and control—if you can master the timing and combos, it becomes a deadly weapon in the right hands.
I also recommend pairing this style with a solid shield or ranged weapon to help you manage the slower attack speeds. One thing I found helpful was to practice on weaker enemies first to get the feel of the combos.
Two Sword Style
Now, the two-sword style is where things get really fun. The moveset allows you to pull off some incredibly stylish combos, and it’s definitely my preferred option. It’s faster than the one-sword style and offers a lot more opportunities for dealing damage. Musashi’s spin move, for instance, is a devastating AoE attack that can wipe out groups of enemies in a flash. The two-sword style also lets you chain combos together, making it perfect for more aggressive playstyles.
However, the biggest challenge with this style is stamina management. Since you’ll be spamming combos, it's easy to run out of stamina, leaving you vulnerable to counterattacks. The key here is to learn the optimal rhythm for using your abilities without exhausting yourself in the process.
How Does It Perform in New Game Plus 8?
Playing in New Game Plus 8 is a test of skill for any Elden Ring player, and using a modded moveset makes the challenge even more daunting. The enemies at this stage are tougher than ever, and while the Ghost of Tsushima moveset has a lot of flair, it may not always have the raw power needed to take down enemies efficiently. You’ll find that while the mod offers a unique combat experience, it doesn’t always measure up to the more optimized builds.
For instance, even with the Musashi moveset, you’ll notice that certain bosses in New Game Plus 8 will still hit like trucks. The slow attack speed can make it hard to react to fast-moving enemies, and the mod’s lack of inherent buffs compared to some of the game’s top-tier weapons means you’ll need to rely more on your dodging and positioning.
However, that doesn’t mean it’s impossible. I actually found the challenge exhilarating. It forced me to really focus on parrying, dodging, and timing my attacks perfectly. For a player who's used to the fast-paced combat of Elden Ring, this mod requires a new level of strategy and patience.
Combat Tips for the Ghost of Tsushima Moveset
Timing Is Everything
One of the biggest challenges when using this moveset is getting the timing right. Musashi’s attacks, while powerful, are not fast, so you need to time your dodges and attacks carefully. It’s not about spam; it’s about precision.
Combo, Combo, Combo
The two-sword style opens up a lot of combo potential. When you start to get the hang of it, you’ll feel like a true swordmaster. Try experimenting with light and heavy attacks to chain combos together. This is especially useful when you’re facing groups of enemies or boss encounters.
Utilize the Spin Attack
The Mousashi spin is a game-changer. This AoE attack can deal significant damage in tight situations. Use it when you’re surrounded or need to clear multiple enemies quickly.
Be Patient
This mod is not for the faint of heart. You’ll need to slow down and focus on careful positioning and dodging. Even with powerful attacks, Musashi can be vulnerable, especially against fast bosses or enemies.
Focus on Stamina Management
Using two swords can deplete your stamina quickly, so be sure to manage it carefully. You can’t afford to be too reckless with your attacks, especially in harder difficulties like New Game Plus 8.
Should You Buy Elden Ring Runes for This Challenge?
If you find yourself struggling in the higher difficulties and need a little extra boost, it might be worth considering purchasing Elden Ring runes. A lot of players opt to buy runes in order to level up their character faster or acquire powerful gear, especially in high-stakes situations like New Game Plus 8.
For those looking for an instant delivery service, U4GM is one of the popular platforms where you can buy Elden Ring runes quickly and securely. They offer a smooth experience with quick delivery, allowing you to focus more on the gameplay and less on grinding for resources.
: Is the Ghost of Tsushima Mod Worth It?
In , the Ghost of Tsushima move set mod offers an exciting and unique way to experience Elden Ring. If you’re looking for something different from the usual gameplay, this mod provides a fresh challenge that requires skill, patience, and precision. While it might not be the most efficient way to plow through New Game Plus 8, it adds a layer of fun and immersion that you won’t get from the standard weapons.
However, if you find yourself getting frustrated or need a little extra help, buying Elden Ring runes could be a great way to smooth out the difficulty curve. U4GM’s instant delivery service can get you the runes you need to power through the tougher sections.
Mastering the Ghost of Tsushima Move Set in Elden Ring: A Complete Guide for Unrivaled Combat
BouncyBear
fomixira
Re: Mastering the Ghost of Tsushima Move Set in Elden Ring: A Complete Guide for Unrivaled Combat
Я выбрал ПокерОК, потому что официальный сайт онлайн покерок предлагает отличные бонусы и регулярные акции. Здесь я играю в покер на реальные деньги и доволен стабильными выплатами. Вход в покерок всегда работает, а интерфейс очень удобный даже на телефоне. Онлайн покерок — это современно, честно и выгодно.
