I've been grinding the Lord of Hatred season like crazy lately, and the community's losing it over a new way to save Greater Affixes. If you're hitting the endgame, you know GAs are everything. It's soul-crushing to find a 3GA piece only to have the Horadric Cube wipe out your best stat. Some people are even looking into Diablo 4 Boosting for sale just to get ahead of the curve before things get patched. I was skeptical at first, but I tried it on a weapon I'd been hoarding, and it actually works. It's a total lifesaver for anyone tired of the RNG gods ruining their perfect rolls. You spend hours farming only to see a bad click destroy your hard work, but this changes the math completely.
The Simple Trick to Save Your Gear
The whole process is honestly way easier than it sounds. You just head to the Enchanter and select that one massive Greater Affix you can't afford to lose. Hit reroll, but don't actually swap the stat for anything new. Just pick the original roll again. For some reason, the game flags that specific slot as "enchanted," and that's the magic part. Once it's flagged, the Horadric Cube seems to ignore it when you're doing other crafts. I tested this on a big Vulnerable Damage roll and then spammed Focused Rerolls. The Cube didn't touch my GA once. It's like giving your gear a permanent safety net that stays active through the whole crafting process.
Maximizing Your Crafting Success
There's a bit of a strategy to make sure you don't brick your items. I always lock the most important GA first before doing anything else. Once that's safe, I use Focused Rerolls to hunt for the other stats I need for my build. It's way less risky than going for a Chaotic Reroll, which is basically just gambling with your sanity. The grind for Primordial Dust is absolutely brutal this season, so you don't want to waste materials on a gamble that's likely to fail. Most players I know are being super careful now because one mistake can ruin a week's worth of farming. It's all about minimizing the risk while you're chasing those perfect Best-in-Slot pieces.
Taking Control of the RNG Grind
What's really cool is that this trick isn't just for legendary gear. It seems to work on charms and uniques too, which is huge for fine-tuning those final pieces. I managed to save a top-tier set charm yesterday while fishing for a better bonus, and it felt great to actually have some control. Since the material costs are so high, I've seen plenty of guys head over to U4GM to pick up extra mats or base items to keep their crafting sessions going. It makes the whole process way less stressful when you aren't constantly worried about running out of resources. If you've got a 3GA piece sitting in your stash because you're too scared to touch it, you should definitely give this a go. It's made my gearing process way more manageable, and I'm finally finishing builds I thought were impossible.
U4GM What I found to lock GAs and save my best D4 items
LunarTinker
