Forza Horizon 6 Graphics Settings for Maximum FPS
lonevessel
#1 Сообщение lonevessel »
If you want smooth, high-FPS gameplay in Forza Horizon 6, you need to tweak both video and graphics settings carefully. The goal is to keep the game looking good while reducing heavy features that tank performance, like ray tracing, shadows, and volumetric fog. Here's a practical guide from an experienced gamer.
Video & Display Settings
Resolution: Use your monitor’s native resolution. Let DLSS, FSR, or XeSS handle upscaling for better FPS without making the game blurry.
Frame Rate: Unlocked (Variable). This gives you the highest possible FPS.
Vertical Sync (V-Sync): Off. Helps reduce input lag and unlocks frames.
Fullscreen: On. Fullscreen mode improves performance stability.
Motion Blur: Off. Makes fast action clearer.
Upscaling Options
Nvidia GPUs: Use DLSS set to Balanced or Performance.
AMD/Intel GPUs: Use FSR 3.1 or XeSS set to Balanced.
Frame Generation: On (if supported), but only after stabilizing baseline FPS.
Graphics & Performance Settings
Ray Tracing
Raytraced Reflections Quality: Off (massive FPS hit).
Ray Traced Global Illumination Quality: Off (saves a lot of performance and avoids grainy lighting).
Reflection & Lighting
Screen Space Reflections (SSR) Quality: Medium or High (good balance).
Screen Space Global Illumination (SSGI) Quality: High (keeps lighting accurate without ray tracing).
Shadows
Shadow Quality: Low or Medium.
Sun Shadow Quality: Medium.
Night Shadows: Off or Low.
Environment & Effects
Volumetric Fog Quality: Off or Low (reduces strain during dynamic weather).
Shader Quality: Medium or High.
Car Level of Detail (LOD): Medium (reduces VRAM load and prevents stutters).
Environment Geometry Quality: Medium.
Deformable Terrain Quality: Medium.
Particle Effects Quality: Low or Very Low (saves GPU cycles).
Performance Tip
CPU Usage: Forza Horizon 6 uses up to 10 CPU cores aggressively. Micro-stutters can happen even at low graphics settings if your CPU is maxed out. One trick: lower Audio Quality to Low or Very Low. This frees up a bit of CPU for smoother gameplay.
brosce
Re: Forza Horizon 6 Graphics Settings for Maximum FPS
#2 Сообщение brosce »
This usually isn’t a local setup problem, it’s more about unstable or poorly synced mirrors upstream. If the main entry keeps breaking, switching to a more consistently maintained mirror list is typically the only reliable fix.Broken Screen
