Total Hidden Rewards on the May Flowers Map
According to tracking data from the May Flowers Conquest map overview on Showdd Showdd May Flowers Conquest Tracker, there are 8 hidden rewards scattered across the board:
4 The Show Packs
2 Headliners Packs
1 Ballin’ is a Habit Pack
1 Deluxe Pack
These are in addition to the standard Conquest completion rewards, which makes this map especially worth fully clearing if you’re trying to stock up on packs early in the cycle.
Where to Find the Hidden Rewards
The May Flowers map is designed like a stylized flower bouquet, with multiple branching petals, a central core, and connecting stems. The hidden rewards are not random—they follow the structure of the design.
Flower Centers
The central nodes of each flower shape are the most important points on the map. These “pistils” usually contain the higher-value hidden packs, including the Ballin’ is a Habit Pack. If you’re planning your route, prioritize pushing into these central areas after securing nearby strongholds.
Outer Petal Tips
The far edges of each flower petal are easy to overlook. These corner tiles often contain standard The Show Packs. They’re not hard to claim, but many players miss them because they expand outward too quickly toward enemy bases instead of fully clearing the edges.
Leaves and Stem Pathways
The green stem-like paths at the bottom of the map are another key area. These linear routes tend to hide at least one Headliners Pack. Following these paths carefully ensures you don’t leave easy rewards behind while focusing on conquest progression.
Areas Near Strongholds
One of the most commonly missed tricks is checking the empty tiles right next to strongholds before you engage them. In some cases, especially around teams like the Nationals, you can simulate or expand into adjacent blank territories first and pick up hidden rewards without triggering any game.
This is often where players accidentally leave packs behind simply because they prioritize battles over full map coverage.
Map Completion Bonuses
Once you’ve collected all hidden rewards, finishing the Conquest map still gives additional guaranteed rewards:
93 OVR All-Star Jim Rice (LF, Boston Red Sox)
4,000 Main Program XP
20 The Show Packs bundle upon completion
The 20-pack reward is especially important because the map is repeatable. You can reset it, clear the 11 strongholds again, and farm those packs multiple times. However, the hidden rewards do not reset on repeat runs, so you only get those once per completion.
The May Flowers Conquest Map in MLB The Show 26 is less about difficulty and more about attention to detail. If you only rush strongholds, you’re leaving value on the table. But if you take the time to fully expand into every corner of the flower-shaped layout, you’ll walk away with significantly more packs than expected.
MLB The Show 26 Conquest Mode – How to Find May Flowers Map Hidden Rewards
FrostRogue7
