The CDA96 GHH RAND Air End 39230743 Ingersoll Rand is an important replacement component for compatible industrial air compressor systems. Choosing the correct air end helps maintain stable operation, reduce unexpected downtime, and support long-term equipment performance. Before purchasing, buyers should understand its features, compare related models, and consider after-sales service.Get more news about CDA96 GHH RAND Air End 39230743 Ingersoll Rand,you can vist our website!
Understanding CDA96 GHH RAND Air End 39230743
The CDA96 air end, part number 39230743, is listed as an Ingersoll Rand air end component. It is designed for the corresponding compressor configuration and should be selected according to the equipment's original specifications.
An air end plays a central role in the compression process. Its operating condition can influence compressor efficiency, output stability, and maintenance requirements.
When sourcing this component, buyers should check:
Exact model and part number.
Compressor compatibility.
Product condition and manufacturing origin.
Technical documentation and warranty terms.
Checking these details before ordering can help prevent installation problems.
CDA96 vs. CDA80 vs. CDB68: Which Is Suitable?
Ingersoll Rand offers several GHH RAND air end models, including CDA80, CDA96, and CDB68. Although they belong to the same product family, they are not automatically interchangeable.
CDA80: This model is another option for compatible compressor configurations. Buyers should compare its original part number and equipment requirements before selecting it.
CDA96: Part number 39230743 is specifically associated with the CDA96 model. It is worth considering when replacing the corresponding original component.
CDB68: This model has a different designation and part number, 39249107. It should not be treated as a direct replacement for CDA96 without technical confirmation.
The best choice depends on compressor specifications, operating requirements, and compatibility rather than model names alone.
Purchasing and After-Sales Service
Price is important, but it should not be the only purchasing factor. Buyers should compare genuine parts, alternative replacement products, delivery arrangements, and warranty coverage.
Before placing an order, ask the supplier to confirm:
Whether the product is genuine or an aftermarket replacement.
Whether it is new, refurbished, or tested.
Available inspection reports and technical documents.
Delivery time and packaging arrangements.
Warranty coverage and return conditions.
Reliable after-sales support is equally important. Professional suppliers should provide installation guidance, technical assistance, and clear warranty procedures.
If problems occur after installation, provide the supplier with the part number, compressor model, operating conditions, and fault details. This information helps technicians identify possible causes more efficiently.
