How to Overwhelm Targets with FS-37 Ravager - Helldivers 2
BlazeTiger
#1 Сообщение BlazeTiger »
In Helldivers 2, one of the most satisfying ways to control the battlefield is by using the FS-37 Ravager. This heavy-hitting weapon is designed for players who love to dominate multiple targets at once, making it ideal for both solo runs and coordinated team plays. In this guide, I’ll break down some practical tips on how to maximize the FS-37’s potential, from loadout choices to strategic positioning.
Understanding the FS-37 Ravager
At first glance, the FS-37 Ravager might seem like just another high-damage weapon, but its real strength lies in its area control capabilities. Unlike precision rifles or close-range shotguns, the Ravager excels at dealing massive damage across a wide radius. This makes it perfect for clearing groups of enemies that are swarming your objective points.
One thing I’ve noticed during my runs is that timing your shots matters more than spamming them. Since the Ravager has a noticeable reload and cooldown period, lining up your attacks to hit clusters of enemies rather than single targets will multiply your efficiency. It’s a weapon that rewards patience and tactical thinking, which makes the battles feel really satisfying when executed correctly.
Optimal Loadouts and Team Support
To fully utilize the FS-37, pairing it with supportive gear is key. Armor that enhances mobility can make a huge difference, letting you dodge incoming fire while positioning yourself for maximum blast impact. Some players like to complement it with a personal shield or deployable turrets to anchor objectives while the Ravager takes out enemies from a slight distance.
If you’re looking to expand your equipment options quickly, one way to get there is by using in-game resources to buy Helldivers 2 medals. Medals help unlock high-tier gear and allow you to experiment with different weapon combinations, which is especially helpful if you want to see what synergizes best with the FS-37.
Positioning and Target Priority
When using the FS-37 Ravager, positioning is almost as important as aiming. This weapon is not forgiving in close quarters; getting too close to a swarm can be deadly. I usually place myself on slightly elevated terrain or behind natural cover, which gives me a clear line of sight to enemy clusters while minimizing risk.
Target prioritization is another factor. Focus first on fast-moving or explosive enemies, as they pose the most immediate threat. Once the dangerous units are down, the Ravager will easily mop up the remaining mobs. And don’t forget to coordinate with your teammates—having someone draw aggro while you blast away makes the experience much smoother and less stressful.
Efficient Medal Farming
For players who are still building up their arsenal, knowing the best place to buy Helldivers 2 medals can save a lot of grinding time. While there are multiple options, choosing a reliable platform ensures you get what you need without worrying about delays or inconsistencies. Personally, I prefer sticking to trusted providers like U4GM, as they consistently offer safe and fast service. Just make sure to keep track of your medal balance, as running out mid-mission can seriously limit your gear choices.
Practical Tips for FS-37 Success
Here are a few personal tips that helped me get the most out of the FS-37 Ravager:
Avoid chokepoints: Blast radius can hurt teammates. Always be mindful of where your squad is positioned.
Timing is everything: Wait for enemies to cluster before firing; it’s better to hit many at once than waste ammo on single targets.
Combine with mobility skills: Sprint boosts or jetpacks can help you reposition quickly after a shot.
Check ammo periodically: Running dry at a critical moment is frustrating; keep a mental count of your remaining rounds.
Practice makes perfect: The Ravager’s unique rhythm requires a bit of adjustment, so don’t be discouraged if it feels awkward at first.
The FS-37 Ravager is a powerhouse for anyone looking to dominate objectives in Helldivers 2. With the right loadout, positioning, and strategy, you can clear enemy waves efficiently while providing invaluable support to your team. Whether you’re farming medals, experimenting with gear, or leading a squad through tough missions, mastering the Ravager is both rewarding and fun.
FAQ
Q1: How do I unlock the FS-37 Ravager?
A1: It can be unlocked through mission progression and by spending in-game medals. Completing certain objective-based missions also increases your chances.
Q2: What is the ideal range for the Ravager?
A2: Medium range is optimal. Too close and you risk self-damage; too far and the blast damage decreases significantly.
Q3: Can the FS-37 Ravager hit multiple targets at once?
A3: Yes, it’s designed for area-of-effect damage, making it perfect for groups of enemies.
Q4: Is the Ravager good for solo play?
A4: Definitely, but you need to be careful with positioning and timing since you won’t have teammates covering flanks.
Q5: Can I trade FS-37 or medals?
A5: No, weapons and medals are bound to your account and cannot be traded.
Q6: Are there events that increase medal rewards?
A6: Yes, seasonal missions and special events often provide bonus medals.
Q7: How often should I upgrade my loadout for the Ravager?
A7: Upgrade whenever you unlock new armor or gadgets that improve mobility or defense to fully capitalize on the FS-37’s potential.
Q8: What is a safe way to get more medals quickly?
A8: Using trusted platforms like U4GM is one approach to get medals efficiently without excessive grinding.
Related Topic: Helldivers 2 Supply Pack Guide: How It Works, Builds, and Best Practices
