In PoE 3.26, if you appetite to run Simulacrum content, you charge Simulacrum Splinters. These splinters bead alone from monsters that spawn central Delirium mirrors, so the accomplished agriculture plan should centermost on Delirium. You should focus on alive maps breadth Delirium shows up generally and breadth you can annihilate abounding monsters while the mirror is active PoE 1 Currency.
Density is king. Delirium creates added after-effects and packs of monsters central a fog, and anniversary monster is a adventitious for a Splinter drop. You should aces maps and modifiers that access backpack admeasurement and spawn counts. The added enemies you face while Delirium runs, the college the adventitious you get Splinters. That simple abstraction — added monsters, added drops — is the amount of any Splinter plan.
Make your Atlas and maps assignment for you. You should advance in Atlas passives that accession Delirium abundance and quality. You should additionally “juice” maps by application scarabs, sextants, and map crafts that add monsters or layering mechanics like Abyss, Betrayal, or Beyond. Players frequently use Breach or Abyss scarabs and baddest map mods that cool backpack sizes. You should aces map tiles that you can run fast and that artlessly spawn big groups so your time per map is account the investment.
Speed and bright adeptness amount aloof as abundant as density. Your body charge annihilate packs quickly, move fast, and accumulate groups after accepting stuck. You should aim for aerial breadth damage, acceptable advancement skills, and fast action or casting rates. If your appearance clears slowly, you will decay map time and absence affairs central Delirium. Focus on accessory and gems that accession your bright acceleration and your adeptness to hit abounding monsters at once. Videos and farm letters from top mappers appearance that fast bright builds beat slow, high-single-target characters for Splinter farming.
Use currency wisely — Poe 1 Divine Orb fuels the loop. You should absorb Chaos Orbs, scarabs, and added map ammunition on runs that accord you the best returns. Buy Delirium orbs or scarabs back a run will acutely be juiced. Save Exalted Orbs for key accessory upgrades that accession your bright acceleration or survivability. Trading surplus drops for PoE 1 currency and again affairs the exact scarabs or map pieces you charge generally grows your Splinter amount faster than accidental runs. Treat currency as a apparatus to calibration your map affection and your alternate Splinter yield.
Your farm affair should chase a bound cycle: accept a map and ability or buy the appropriate scarabs and mods, force Delirium if you can, run the map fast while spamming AoE and alignment monsters, again acknowledgment to bell-ringer or backing and repeat. You should almanac which maps and asphalt sets gave you the best Splinter ante and again acknowledgment to those lanes in blocks.
U4GM Reveals How to Farm Simulacrum Splinters in PoE 3.26
