There's something oddly satisfying about watching a planet crack apart under a barrage of asteroids, or seeing a sun swell and swallow its neighbors. Solar Smash is a physics-based simulator built around exactly that kind of destruction. It doesn't ask you to win or lose. Instead, it gives you a cosmic sandbox, a set of tools, and a lot of room to experiment. If you're curious about it, this guide will walk you through how the game works, what to try first, and a few tips to make the most of your time among the stars.
Gameplay: What You'll Actually Be Doing
The core loop in Solar Smash is simple. You start with a solar system, which might include a star, a handful of planets, moons, and sometimes asteroids or other celestial bodies. Everything in the simulation follows real-ish gravitational rules, so objects pull on one another, orbit in predictable paths, and collide in ways that look convincing.
Your main job is to cause trouble. The game provides a variety of tools and weapons that you can use to alter the system. You can fire projectiles, drop in new bodies, adjust masses, and watch how gravity and momentum carry the chaos forward. Some effects are dramatic, like a large body slamming into a planet and sending debris spiraling outward. Others are subtle, like a small nudge that gradually shifts an orbit until something drifts into a new path.
The physics is the real star here. Because the simulation tracks forces, mass, and velocity, the results often surprise you. A tiny object hitting at the right angle can change the entire trajectory of a planet, and a seemingly minor collision can set off a chain reaction across the system. Part of the fun is developing an intuition for these cause-and-effect relationships.
Many players start by simply playing with the default setups. Pick a weapon, aim at a planet, fire, and see what happens. Then gradually work toward more deliberate scenarios, such as trying to break apart a moon without disturbing the rest of the system, or building a setup where one collision triggers another.
Tips for a Better Experience
Start small and build up. It's tempting to go straight for the biggest weapons, but smaller impacts teach you how the physics responds. Once you understand how a small rock affects a moon, you'll have a much better sense of what a planet-sized object will do.
Experiment with angles and speeds. Many of the most interesting results come from changing one variable at a time. Try the same projectile at different velocities or approach angles and compare the outcomes. You'll quickly notice how sensitive orbits and debris patterns are to small changes.
Watch the aftermath. Destruction is only half the story. Pause occasionally and observe how debris settles, which fragments get captured by gravity, and which ones escape. Some of the best moments happen long after the initial impact.
Set up your own challenges. Give yourself goals like "destroy this planet using only three shots" or "create a debris ring around the sun." Self-imposed constraints can turn a sandbox into a puzzle and keep things fresh.
Save interesting setups. If you create a system that produces a striking result, take a screenshot or note the conditions so you can revisit it later. Many players enjoy sharing their favorite scenarios on forums, and it's a nice way to discover techniques you hadn't considered.
Be patient with the simulation. Orbital events can unfold slowly. A moon may take a while to drift into the path of a planet, so give things time before assuming nothing will happen.
Conclusion
Solar Smash rewards curiosity. It's less about achieving a specific goal and more about enjoying the spectacle of physics in motion, watching gravity do its work and seeing how small choices ripple across an entire system. Whether you're a fan of science, an admirer of big explosions, or just someone who enjoys messing with miniature universes, it offers a playful way to explore how celestial bodies behave. Approach it with an experimental mindset, take your time, and don't be afraid to see what happens when you push things a little too far. Happy smashing!
