Aion 2 Mid-Game Weapons: Noble Dragon Lord Greatsword Breakdown
lonevessel
#1 Сообщение lonevessel »
The Noble Dragon Lord Greatsword is a Heroic-grade two-handed weapon designed for Elyos Gladiators. It becomes usable at level 45, with an item level of 108, which places it firmly in the mid-game progression range.
In general, most players see this weapon as a bridge weapon. It is not an early leveling sword, and it is not true endgame gear either. Instead, it usually fills the gap between dungeon drops in the early 40s and high-tier PvE or PvP weapons later on.
Because it is tradable, storable, enchantable, and decomposable, it fits well into most players’ normal gear management habits.
How Strong Is the Base Damage in Practice?
The listed attack range is 463–627, which is solid for a level 45 greatsword. In practice, most Gladiators notice that the weapon feels consistent rather than bursty. The damage floor is not low, which helps with stable PvE clears.
The weapon also provides:
Accuracy: 100
Critical Hit: 150
PvE Damage Boost: 5%
For most players, that PvE damage boost is more important than it looks on paper. When fighting dungeon mobs or elite enemies, the damage bonus applies all the time, not just on crits or specific skills.
This makes the sword feel reliable during long dungeon runs rather than flashy in short fights.
Is This Weapon Better for PvE or PvP?
In general, the Noble Dragon Lord Greatsword is more PvE-oriented.
The reasons are simple:
The PvE Damage Boost directly improves dungeon performance.
The stat spread focuses on accuracy and sustained damage, not burst.
There is no built-in PvP damage or defense scaling.
That said, most players will still use it in casual PvP if they don’t have a dedicated PvP weapon yet. The accuracy and critical hit stats help against evasive targets, but it will usually lose to optimized PvP weapons at the same level.
How Important Are the Magic Stone and Divine Stone Slots?
This weapon has:
5 Magic Stone slots
1 Divine Stone engraving slot
In practice, five magic stone slots give a lot of flexibility. Most Gladiators usually socket:
Attack stones
Critical Hit stones
Or a mix of Accuracy and Crit, depending on content
The single divine stone slot is standard for this tier. Most players don’t expect anything special here, but it does allow you to add utility effects that slightly improve combat consistency.
Overall, the slot setup matches what most players expect from a Heroic greatsword.
What Does Soul Imprint Actually Change?
Soul Imprint is where this weapon becomes more interesting.
When initially imprinted, it grants 6 random bonus stats, drawn from a large pool that includes:
Might
Precision
Attack
Accuracy
Critical Hit
HP / MP
Combat Speed
Status Effect Chance
Multi-hit Chance
Critical Attack
Back Attack
Block
Weapon Damage Boost
In practice, most players do not aim for perfect rolls. Usually, players are happy if they get:
Combat Speed
Weapon Damage Boost
Critical Attack or Back Attack
The ranges are wide, so rerolling can be expensive or time-consuming. Most Gladiators settle once they get two or three useful stats and move on.
How Does Enchanting and Exceeding Affect Performance?
The weapon supports:
Max Enchant: +20
Max Exceed: 5
Enchanting provides steady power increases, but most players stop somewhere between +10 and +15 due to risk and cost. Going to +20 is usually reserved for players who plan to keep the weapon for a long time.
Exceed levels give extra scaling and usually feel more impactful than early enchants. In general, exceeding this weapon to +3 or +4 is common before players replace it with higher-tier gear.
How Do Most Players Obtain This Weapon?
The Noble Dragon Lord Greatsword is obtained through crafting.
This means:
You either invest time in gathering and crafting
Or you acquire it through player trade after someone else crafts it
Because it is tradable, it circulates fairly often. Some players who don’t craft themselves still end up using it because it fits neatly into level 45 progression.
You may occasionally see people searching phrases like Buy cheap Aion 2 items from U4N store when looking for gear options, but most experienced players still compare stats carefully before committing to any weapon.
Is This Weapon Worth Using Long-Term?
Usually, no.
Most players replace the Noble Dragon Lord Greatsword once they reach higher-tier dungeon weapons or specialized PvP gear. Its strength is not longevity, but efficiency during a specific leveling window.
It shines when:
You are entering level 45 content
You want stable PvE performance
You don’t want to gamble on rare drops
It falls off once enemies demand higher penetration, PvP scaling, or class-specific bonuses.
Who Should Use This Weapon?
In general, this weapon makes sense for:
Gladiators focused on PvE
Players who want predictable performance
Players who prefer crafting paths over RNG drops
It is less ideal for:
PvP-focused Gladiators
Min-max players chasing perfect endgame stats
Players already close to level cap
The Noble Dragon Lord Greatsword is not exciting, but it is dependable. Most players who use it appreciate that it does exactly what it promises: solid damage, flexible stats, and reasonable scaling for mid-game content.
Вернуться в «Игровые архивы»
