McCunyao
#1181 Сообщение McCunyao »
I'm having a bit of a difficulty trying to rip Phantasy Star Universe (And its expansion) player models. Seems like some triangles have a secondary UV overlapped, causing the ripper to not extracting those specific triangles.
#1182 Сообщение Tosyk »
McCunyao писал(а):I'm having a bit of a difficulty trying to rip Phantasy Star Universe (And its expansion) player models. Seems like some triangles have a secondary UV overlapped, causing the ripper to not extracting those specific triangles.
provide ripper's log here so we can examine the issue.
McCunyao
#1183 Сообщение McCunyao »
Here you have.
PsuIlluminusOff.exe.log.7z
(3.95 КБ) 1032 скачивания
#1184 Сообщение black_ninja »
Load problem mesh file one by one and try texcoord idx 9/10 or 11/12 or 6/7.
Check for correct texture coordinats in UV map in 3DMax
McCunyao
#1185 Сообщение McCunyao »
I've tried to load the files who should have the missing triangles, but I'm not getting the missing ones by changing the UV Coord parameters.
I do have found my missing triangles though:
After selecting and de-selecting the triangles a couple of times they become un-selectable, like they get deleted and reverted to edges.
#1186 Сообщение Tosyk »
McCunyao, I don't think those edges are usable in any way. They are penetrating the mesh to connect random vertices and appears as a garbage. Just convert your mesh in Editable Poly and they'll be removed.
#1187 Сообщение Kirov »
Проблема с игрой Empires: Dawn of the Modern World. Игра на DX8. При рипе создаётся пуская папка Frame XXXX. Лог прилагается.
Торрент на игру: http://fast-bit.org/torrent/154501/impe ... ld-2004-pc
empires_dmw.exe.log.rar
(3.08 КБ) 1062 скачивания
#1188 Сообщение black_ninja »
Kirov, ошибка исправлена.
В след. версии будет
HaCKer_UTD
#1189 Сообщение HaCKer_UTD »
У почему-то не все меши захватываются из некоторых старых игр. Например из Most Wanted 2005, кам хаком определенный кусочек в поле зрения беру и рипаю - мешей не хватает их штук 700, а если старым Dx ripper'ом файлов где-то 1200 и всего хватает.
#1190 Сообщение black_ninja »
Скиньте лог, может ошибки при рипе есть.
И попробуйте несколько фреймов рипать. Несоколько раз нажимать ф10, в общем.
