Block Blast Strategy Blueprint for Beginners: A Simple System to Score Higher
В этом разделе собраны ссылки на оружие из самых разнообразных игр
safatigers
#1 Сообщение safatigers »
Introduction
Block Blast becomes much easier when you stop “placing blocks” and start running a system. The grid is your resource, and every move either increases or decreases future options. This guide gives you a beginner-friendly blueprint you can follow every run—perfect if you want consistent improvement instead of random highs and lows.
What Is Block Blast ?
Block Blast is a block puzzle game where you place different shapes on a grid. Completing full rows or columns clears them for points and creates space. The run ends when the current blocks can’t fit anywhere.
The Rules (Quick and Clear)
Drag and drop pieces onto the board
Clear full rows/columns to score and open space
No clears = board fills up
Game ends when none of the offered pieces fit
The Beginner Blueprint (Use This Every Turn)
Step 1: Scan all blocks before moving
Ask: which piece is biggest or most restrictive? Those usually dictate your placement.
Step 2: Identify your “clearing lanes”
Choose at least one row plan and one column plan you’re building toward. If you only build horizontally (or vertically), one bad set of pieces can trap you.
Step 3: Protect an open zone for big pieces
Always keep a flexible region where a long bar or square can be dropped without wrecking your board.
Step 4: Place from the center outward
Center placements create more potential line completions than edge placements, and they reduce dead corners.
Step 5: Prefer moves that create a clear within 1–2 turns
Immediate clears are great. But a move that sets up a guaranteed clear next turn can be just as valuable—especially if it improves your board shape.
High Score Strategies (Once You Stop Dying Early)
Aim for combo clears by completing multiple lines at once
Avoid overbuilding in one area; uneven boards reduce fit options
Learn common shapes: long bar, square, L/T shapes—each has “natural” homes
Never rush. The best players treat each placement like chess.
Why Block Blast Hooks You
It’s simple to understand but endlessly variable. Every run is a new spatial puzzle, and the satisfaction of combo clears makes improvement feel immediate.
Conclusion
To score higher in Block Blast, you need a repeatable process: plan with all blocks, keep the board open, maintain clearing lanes, and save space for big pieces. Follow this blueprint and you’ll see longer runs, more clears, and bigger scores.
Вернуться в «Оружие (Weapons)»
