Pokémon Legends ZA: The Fastest Way to Shiny Hunt Any Pokémon
BlazeTiger
#1 Сообщение BlazeTiger »
Shiny hunting has always been one of the most thrilling—and sometimes frustrating—activities in the Pokémon series. But in Pokémon Legends ZA, a clever new method has emerged that makes finding your dream shiny Pokémon easier than ever. This approach works on nearly any Pokémon in the game, including the beloved starters like Charmander and Tepig. Below is a detailed breakdown of how this method works, how to apply it efficiently, and what you should keep in mind to maximize your shiny odds.
Understanding the New Shiny Hunting Method
The technique showcased in the video relies on manipulating the day–night cycle of the game. The core idea is to save your game right before the in-game time transitions between night and day (or vice versa). By doing this, you can repeatedly reset the game to refresh the Pokémon spawns without losing much time.
In practice, here’s how it works:
Wait for a time transition – When it’s about to become day or night, find a good spawn area and prepare to save.
Make a “hard save” – This must be done before any aggressive Pokémon notice you; otherwise, you won’t be able to save.
Reset and reload – After saving, check the Pokémon that spawn. If no shiny appears, reset and reload your save.
Repeat the process – Continue until a shiny appears.
This method functions like a portable bench reset, allowing you to effectively control spawn refreshes anywhere in the wild zones. It’s especially efficient in Wild Zone 20, where multiple fire-type starters and alpha Pokémon can appear at once.
Why It Works So Well
Unlike traditional shiny hunting that depends on slow fly resets or repetitive area reloads, this strategy reduces downtime dramatically. Each reset only takes around ten seconds, meaning you can check dozens of spawn cycles in just a few minutes.
Moreover, this method allows players to target multiple Pokémon at once—for example, hunting Charmander and Tepig simultaneously while also checking for random shiny alphas nearby. Because Wild Zone 20 is divided into several sections, you have the chance to encounter multiple starters per cycle, increasing efficiency.
It’s important to note that if you do encounter a shiny, you must catch it before resetting—simply turning off the game after spotting it won’t save your progress. This means the method must be done manually, without automation or macros.
Ideal Pokémon for This Method
While the method was demonstrated using fire-type starters, it can be applied to almost any Pokémon, including rare ones like Riolu, which only spawns during the day. If you save just before dawn, the time transition will trigger Riolu’s daytime spawns, giving you a consistent chance to roll for a shiny version.
For players who like to experiment or want to expand their shiny collection, this system provides a flexible and highly efficient framework. Whether you’re hunting for common wild Pokémon or rare species, this approach offers a faster and more manageable path toward completing your shiny collection.
Pro Tips for Success
Avoid aggression: Always make sure no Pokémon are targeting you before saving.
Position strategically: Choose locations with multiple desired Pokémon spawns to maximize your reset efficiency.
Track your attempts: Keep count of your resets for better reference, especially if you’re comparing odds between zones.
Be patient: Even with this faster method, shiny hunting still involves luck. Expect some trial and error.
And for those looking to enhance their collection with rare or unique additions, some players opt to buy custom pokemon or buy custom shiny za pokemon for display or online competitions. While these options can’t replace the satisfaction of finding a shiny yourself, they remain an alternative for collectors who want something personalized.
This shiny hunting technique is a game-changer for Pokémon Legends ZA players. By timing your saves around day–night transitions and resetting efficiently, you can target almost any Pokémon species without wasting time on tedious travel or loading screens. Whether you’re chasing your first shiny starter or building a full shiny team, this method is one of the most practical and rewarding options available right now.
