Shiny hunting in Pokémon games has always been an exciting and rewarding challenge, but in Pokémon Legends ZA, it becomes a whole new level of thrill, especially when targeting elusive creatures like Eevee and Absol. In this guide, we'll explore effective shiny hunting strategies for these two Pokémon, along with tips on maximizing your chances and making the most out of your time. Whether you're hunting for a shiny Eevee to evolve into one of its stunning evolutions or chasing a shiny Absol to add to your mega lineup, this guide will give you all the tips you need to succeed.
Where to Find Shiny Eevee and Absol
The first step in successful shiny hunting is knowing exactly where to go. For Eevee and Absol, there's a specific area on the map that offers the best chances of encountering these shiny Pokémon.
You’ll want to head to the location near Wild Zone 18. Once you teleport to the nearby Pokémon center, you’ll need to take an elevator to the rooftop, cross a bridge, and then scale a ladder to reach the area where Eevee and Absol spawn. This location is ideal because it consistently refreshes spawn rates, especially when you use the bench reset method, which I’ll explain in more detail shortly.
Tip: Keep in mind that Eevee only appears during the daytime with clear weather. So, if you're looking for this shiny, be sure the conditions are right before you begin your hunt.
Shiny Hunting Method: The Bench Reset
Now that you know where to go, let’s dive into the best hunting method. The bench reset method is a popular strategy for shiny hunting, especially when you’re targeting specific Pokémon like Eevee and Absol. This method works because each time you change the time of day in Pokémon Legends ZA, the game resets the spawns within a 50-meter radius, giving you a fresh chance at encountering a shiny.
Here’s how to do it:
Get a Turbo Controller: Using a turbo controller will make this process a lot easier. The turbo controller can spam the A button for you, allowing you to reset the time of day and spawn new Pokémon while you step away from your Switch. If you don’t have one, you can still do it manually, but it will be slower.
Use a Rubber Band on Your Joy-Con: Attach a rubber band to your Joy-Con to hold it in place so it keeps running into the bench. This will trigger the reset every time.
Hit the A Button: The turbo controller will rapidly press the A button for you, which is essential for the reset method. You’ll need to hit the A button three to four times during each reset to fully refresh the spawn.
Wait for the New Spawn: After each reset, the game will refresh the Pokémon that spawn in the area. This gives you a new opportunity to encounter a shiny.
Pro Tip: Even without a turbo controller, this method still works, but you’ll need to be more hands-on.
Targeting Shiny Eevee and Absol
Once you’ve set up your bench reset method, it’s time to focus on specific shiny targets.
Shiny Eevee:
Eevee can be a little tricky to find, as it only appears during the day and under clear weather. However, when the conditions are right, it spawns on the rooftop in the area you’ve chosen. To increase your chances, save before you attempt to catch it. You can refresh Eevee’s spawn by repeatedly resetting the time of day with your turbo controller.
Shiny Eevee Tip: Eevee spawns at a specific time, so make sure to check the weather conditions in the game to avoid wasting time.
Shiny Absol:
Absol is a bit more forgiving in terms of its spawn conditions. Unlike Eevee, Absol spawns frequently during resets, even when the weather isn’t perfect. You can also use a run reset method, where you move to the edge of the building and then return to the spawn area to refresh Absol's location.
Shiny Absol Tip: Absol’s spawn is consistent, but keep an eye on its location as you may need to adjust your position to keep it in your range.
Why You Should Buy Shiny Pokémon
For those who don’t want to grind hours on end, you can buy shiny Pokémon to skip the time-consuming hunt. Some platforms, like U4GM, offer affordable options to purchase shiny versions of popular Pokémon, including Eevee and Absol. While buying shiny Pokémon isn’t for everyone, it’s a great way to get the shiny you want if you're not up for the grind.
Additionally, some players look for cheap Legends ZA shiny Pokémon options, especially if they’re seeking high-level shinies like Alpha Absol. This can be a great way to jumpstart your collection without spending excessive time hunting.
Shiny hunting in Pokémon Legends ZA can be both fun and rewarding, especially when targeting rare creatures like Eevee and Absol. The bench reset method is one of the most efficient ways to find shiny Pokémon, but it’s important to be patient and make sure the spawn conditions are right for Eevee. If you don’t have the time or inclination to hunt, there’s always the option to buy shiny Pokémon online. Whether you’re hunting or purchasing, the pursuit of these shiny gems adds a unique aspect to your Pokémon journey.
Ultimate Guide to Shiny Hunting in Pokémon Legends ZA: Eevee & Absol Strategies
FrostRogue7
