PoE 2 Mirror Moments: When to Duplicate an Item
Новости всех разделов в одном месте
FrostRogue7
#1 Сообщение FrostRogue7 »
In Path of Exile 2 (PoE 2), one of the most coveted tools in the game is the Mirror of Kalandra. It allows you to duplicate an item, effectively giving you two of whatever powerful gear or weapon you've been grinding for. But with great power comes great responsibility—and a lot of questions. When should you mirror an item? What makes it worth the significant cost? In this guide, we'll explore the circumstances where duplicating an item is a smart choice and how you can best take advantage of the Mirror of Kalandra.
Understanding the Mirror of Kalandra
The Mirror of Kalandra is a rare and expensive currency item in PoE 2, often considered one of the most sought-after and valuable items in the game. It duplicates an item, creating an exact copy of it, which can then be used, traded, or sold.
Using this powerful tool requires careful thought. You can't just mirror any item in your stash. It’s not something you’ll want to waste on just any rare armor or weapon. The decision of when to mirror an item should be based on value, rarity, and how much you stand to gain from duplicating it.
When Should You Mirror an Item?
Unique or Endgame Gear
The best time to mirror an item is when you come across endgame gear that is perfect for your build or playstyle. Think about a weapon or armor that you can’t easily replace with something better. If it has the right stats, modifiers, or even specific affixes that enhance your build, duplicating it can ensure you have a backup piece or allow you to sell one for a hefty price.
For example, if you’ve crafted the perfect set of gloves or boots that significantly boost your damage or resistances, mirroring them could be a wise investment. It's all about duplicating the gear that can't be easily obtained again.
High-Value Currency Items
Another great reason to mirror an item is when it holds value beyond just its stats in gameplay. Items that are in high demand from other players, such as rare crafting bases or valuable uniques, can fetch high prices in the marketplace. If you're looking to buy cheap PoE 2 currency or items that are hard to find, duplicating high-value items gives you a chance to sell one without losing your access to the original.
Crafting Bases with High Potential
Mirroring a rare item that has a high potential for further crafting can also be an excellent move. If you’ve managed to get a base item with great affixes, duplicating it gives you the opportunity to modify one while keeping the other intact. For instance, you could use one as a base for further crafting or alterations, while the original remains untouched and ready for other uses.
Cosmetic or Aesthetic Choices
Not every item needs to be powerful for you to consider duplicating it. Some players might want to mirror items just for their appearance, like certain cosmetic armor sets or items with specific visual effects. If it’s something you’re particularly attached to in terms of look, duplicating it ensures you can still show it off even if you need to change out gear for gameplay purposes.
The Cost of Duplicating an Item
Mirroring an item isn't cheap. Not only does the Mirror of Kalandra itself cost a significant amount of PoE 2 currency, but the process often requires a considerable amount of time and effort to find the right item to duplicate. So before diving in, make sure that the item you want to mirror is worth the price.
If you’re just getting started or trying to build your currency reserves, it might be tempting to cut corners and buy cheap PoE 2 currency to make the process easier. While buying currency might get you ahead in the short term, always consider whether the item you're duplicating will truly provide long-term value to your character.
Tips for Using the Mirror of Kalandra
Think Long-Term: Is this item something you’ll use throughout your character’s progression, or is it a short-term upgrade? If it's the latter, you might want to reconsider mirroring it.
Check the Market: Some items, while valuable to you, might not have a strong resale value. Make sure you understand what your item is worth both in terms of gameplay and trading before committing to a mirror.
Don't Rush: The Mirror of Kalandra is too precious to rush into using. Spend time considering your options and weigh the pros and cons before duplicating an item.
Frequently Asked Questions (FAQ)
1. Can I mirror any item in the game?
No, you can only mirror non-unique items. The Mirror of Kalandra works on rare or crafted items, but not on unique or legacy items.
2. How do I obtain a Mirror of Kalandra?
The Mirror is extremely rare and often found in high-level maps, or through trading with other players. You can also obtain it by saving up your PoE 2 currency or through specific endgame activities.
3. Is it worth mirroring low-level gear?
Generally, no. It’s best to mirror high-end or rare items that are difficult to replace. Low-level gear typically doesn’t justify the high cost of using the mirror.
4. Can I trade mirrored items?
Yes, mirrored items can be traded just like any other item in PoE 2. This can be a great way to earn PoE 2 currency by selling high-value mirrored items.
5. How do I know if my item is worth mirroring?
The item should be rare, have good affixes, and ideally be something you need long-term or can resell for a significant amount of currency. It should offer more value than what it costs to duplicate it.
6. What should I avoid mirroring?
Avoid mirroring items that are easily replaceable, don’t provide significant gameplay benefits, or don’t have a high resale value. Mirroring should be an investment, not a whim.
7. Can I use the mirror on items with unique properties or affixes?
No, the Mirror of Kalandra only works with rare, non-unique items. You can’t use it on items with affixes that are unique to certain sets or NPC vendors.
With these insights, you’re better equipped to make the call on when to use the Mirror of Kalandra in PoE 2. Whether you’re looking to improve your build or make a smart currency investment, duplicating items can be a powerful tool—if used wisely!
Вернуться в «Новости форума»
