U4GM How to Farm Blueprints in ARC Raiders Cold Snap Tips
iiak32484
#1 Сообщение iiak32484 »
I logged back into the Rust Belt and instantly realised I'd been playing a different game before ARC Raiders Items started popping up in chat and on everyone's shopping lists. Cold Snap Patch 1.7.0 doesn't just add snow. It messes with your habits. You'll be jogging across open ground like normal, then the sky flips and a whiteout rolls in. Visibility goes to nothing. You stop thinking about angles and start thinking, "Where's the nearest roof, and do I have a heat pack?".
Weather That Actually Changes Fights
The blizzards aren't just for show. When the wind picks up, comms get messy and it's way easier to lose your own squad than the enemy. I've had fights where nobody really "won" the gunplay; the cold did. Frostbite ticks while you're trying to loot, heal, and listen for steps that sound like they're coming from everywhere. You quickly learn to route between indoor POIs, warm up fast, then push again. Play too proud, stay outside too long, and you'll pay for it.
Ice, Tracks, and Dumb Ways to Die
Movement's the other big surprise. Frozen lakes are slick in a way that feels funny right up until you're sliding into trouble. People panic-sprint, lose control, and drift straight into a squad holding the shoreline. And the snow tells on you. Those footprints are loud evidence, even when you think you're being clever. If you're flanking, you've got to change your lines, cut through hard cover, or accept that someone's about to follow your trail like it's a map.
Loot, Builds, and the Stuff You'll Actually Notice
Loot's been bumped in a way that's hard to ignore. Blueprint drops feel way more generous, especially on routes that pass through Stella Montis. Extracts have that "one more run" pull again because you're not just scraping by for mats. The quality-of-life tweaks help too: a cheap-ish skill reset means you can mess around with builds without regretting it for a week, and an ADS toggle is one of those small things you don't praise until your hands finally stop aching.
Events Worth Doing While You're Out There
Flickering Flames is the rare event that doesn't feel like homework. You're already sprinting through bushes trying not to freeze, so grabbing candleberries on the move just happens, and the turn-ins stack up into real rewards. If you're the kind of player who'd rather spend your night learning ice routes than farming the same spots, there's also cheap ARC Raiders gear floating around as an option so you can stay focused on raids, extracts, and not becoming a snow-covered loot pinata.
