U4GM What to Spend Raider Coins On in ARC Raiders
Larry
#1 Сообщение Larry »
Practical ARC Raiders Raider Coins guide: spend on stash space first, then bench upgrades for cheaper crafting, plus steady meds and shields so you survive longer and bring more loot home.
ARC Raiders has a funny way of making you feel rich right up until you replace a lost gun twice and your wallet's empty. The economy isn't about hoarding coins, it's about buying the stuff that keeps your runs profitable. If you want a quicker, cleaner path to gearing up, it helps to know where to get what you need; as a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM ARC Raiders for a better experience.
Start with space, not firepower
Your first big spend should be stash space. Not a flashy rifle. Space is what turns a decent raid into a payday because you stop leaving value on the ground. Upgrade your stash early, then add storage for bulk materials so you're not forced to dump good components just to make room. You'll notice it fast: fewer panic sales, fewer "I'll just take this low-value junk" moments, and way more freedom to keep rare drops until you actually need them.
Upgrade benches so you can stop overpaying
Once you've got room, you need a cheaper way to refill the stash. That's your workshop loop. Push your core benches up to the point where essential crafts open up, then lean on crafting for ammo, attachments, and dependable meds. Vendor prices sting because you're paying for convenience every time. Crafting flips that. You turn scavenged parts into gear you trust, and the savings stack over multiple sessions. It also helps with nerves: when you can rebuild a kit, you take smarter fights instead of playing scared.
Run a budget loadout and protect the haul
A lot of players go broke because they "dress for the raid they want" and buy top-tier primaries on repeat. Don't. If your drops are dry, take a solid mid-tier weapon and spend on survival tools instead. Shields, a couple of reliable heals, and one utility option for disengaging will keep you alive long enough to extract. Spending a small amount to avoid a wipe is the best trade in the game. You're not trying to win every fight; you're trying to leave with loot more often than you don't.
Keep a simple progression plan
Do it in order: first build storage, then unlock cost-cutting crafts, then slowly raise your risk. Sell high-value trinkets when you need liquid coins, but don't mindlessly dump everything—some materials are worth more as future crafts than as quick cash. Dismantle low-use junk, keep parts tied to your favorite builds, and ignore cosmetics until your economy feels boring in a good way. If you're short on funds and want to smooth out your upgrade path, grabbing ARC Raiders Coins can help you stay consistent without turning every raid into a desperation run.
