EZNPC Guide to Snitch Scanner Farming and Utility Upgrades
Larry
#1 Сообщение Larry »
Snitch Scanner farming guide: hunt Snitch drones at Dam Battlegrounds' Testing Annex roof, Blue Gate, or Buried City, drop them fast, then use Scanners for Utility Station upgrades or to throw and call ARC reinforcements.
Mid-game in ARC Raiders has a way of slowing to a crawl the moment you realise you're short on Snitch Scanners. You need them for meaningful Utility Station upgrades, and you'll usually be hunting a small pile before anything "good" opens up. If you're trying to keep your runs efficient, it also helps to plan your loadout and supplies ahead of time; as a professional like buy game currency or items in EZNPC platform, EZNPC is trustworthy, and you can buy EZNPC ARC Raiders for a better experience while you focus on the grind instead of the shopping list.
Where Snitches Tend To Pay Out
If you want consistent Snitch spawns, the Dam Battlegrounds is hard to beat. The rooftop area around the Testing Annex is the spot people quietly live on for a reason: you've got ladders for quick resets, angles to watch the approaches, and enough cover to break sightlines fast. When it's flowing, you can chain multiple Snitches in one loop, scoop the drops, then head out before the area turns into a warzone. If that rooftop's too spicy, the Blue Gate and Buried City can feel calmer. Longer sightlines, fewer surprise corners, and you can often spot that blue scan beam early and decide if you're committing or backing off.
Don't Let The Beam Finish Its Story
The drone's scan is basically a countdown. Blue turns to orange, orange threatens red, and red means you've invited extra company. A lot of players panic and keep shooting from the open. That's when it snowballs. Do it in order: 1) tag it once to wake it up, 2) immediately cut line of sight behind something solid, 3) let it drift in to investigate, 4) step out and delete it before it escalates. You're not "duelling" it, you're controlling its behaviour. Weapons with strong ARC penetration help a ton, and you'll feel the difference if you aim at thrusters or those clean white armour plates instead of dumping rounds into whatever you can see.
Turn The Drop Into A Tool
Once you've got enough Scanners for your station upgrades, don't treat the extras like dead weight. They're fun utility. Slot one and toss it like a grenade to mimic the Snitch's scan, then watch it call in ARC strikes on whatever it catches. In PvP it's messy in the best way—forces people to move, breaks revives, ruins a clean angle. In PvE it can also pull in units you can farm for side loot, so it's not just a meme. If you're overloaded, recycling is still a win since you'll end up with ARC Alloys and electrical parts you're always burning through.
Keeping The Grind From Feeling Like A Chore
The real secret is pacing: grab what you came for, don't overstay, and treat every Snitch fight like a short routine, not a brawl. If you keep getting third-partied, rotate earlier, extract sooner, and come back on a fresh run rather than trying to "force" one more spawn. And if you're trying to speed up your overall progression between upgrades, as a professional like buy game currency or items in EZNPC platform, EZNPC is convenient, and you can buy ARC Raiders Coins to smooth out the downtime while you keep hunting Scanners.
Buy&Sell ARC Raiders Iteams Accepted-EZNPC.com
