In ARC Raiders, the Buried City Residential Master Key is a valuable item that grants access to various locked doors throughout the Buried City. As experienced players know, unlocking these doors is crucial for progressing through the game, discovering hidden loot, and completing quests. In this guide, we’ll walk you through everything you need to know about this key, including where to use it, how to get it, and what you can expect when you unlock those doors.
What is the Buried City Residential Master Key?
The Buried City Residential Master Key is an uncommon key item in ARC Raiders. It allows players to open several apartment doors within the Buried City, which is a critical location in the game. The key’s primary function is unlocking these specific doors, leading to additional loot and possibly more challenges or encounters that can help in your progression.
Key Details:
Rarity: Uncommon
Weight: 0.25
Stack Size: 1
Sell Price: 100 Coins
Why is it Important?
Players will encounter locked doors in various areas of the Buried City, many of which are inaccessible without the Residential Master Key. These doors often contain valuable loot, including resources, weapons, or other items that can make your journey easier. For those looking to complete all areas of the Buried City or find rare items, this key is essential.
Where to Use the Buried City Residential Master Key
The primary function of the Buried City Residential Master Key is to unlock apartment doors scattered throughout the Buried City. While the exact locations of these doors can vary, they are typically found in residential complexes or abandoned buildings within the city.
Common Locations to Find Locked Doors:
Abandoned Apartments: These are often found in the northern section of the Buried City and may require the key to access hidden areas with loot.
Residential Complexes: In certain neighborhoods, you’ll find doors that are otherwise inaccessible. The key unlocks these to allow you to explore further and gather essential items.
These doors are often marked by their distinct appearance compared to other structures. Once you approach a locked door, if you have the key, you can interact with it to unlock the passage.
How to Obtain the Buried City Residential Master Key
The Buried City Residential Master Key can be acquired in the following ways:
Scavenging: Like many items in ARC Raiders, the Residential Master Key can be scavenged from the environment. Explore the Buried City thoroughly, and you may find it while looting various containers or debris.
Completing the Quest: "Digging Up Dirt": This is a quest within the game that rewards you with the Residential Master Key. Completing the associated tasks will grant you this key as part of your reward, making it a good idea to track quest progress for key items.
What Happens After Unlocking the Doors?
Once you use the Buried City Residential Master Key to unlock a door, you’ll often be rewarded with valuable loot. These rooms may contain:
Weaponry: Better guns or tools that can help you in your exploration of the city.
Resources: Items necessary for crafting or upgrading your gear.
Quest Items: Sometimes, you’ll find components that are needed to complete other quests in the game.
Opening these doors can reveal new areas or hidden challenges that can give you an edge in your journey through the game.
Tips for Maximizing Your Use of the Residential Master Key
Always Have a Backup: Make sure you have a backup key or a secondary source of unlocking if you’re about to venture into an area where you know there are locked doors. Keys can be valuable, and it's best not to waste them unnecessarily.
Check Every Corner: The doors are not always in obvious locations. Explore thoroughly and check every residential building for hidden entrances or areas that require unlocking.
Consider Upgrades: If you’re constantly using keys in the Buried City, consider upgrading your key scavenging or crafting abilities to ensure you always have a steady supply.
How to Buy Cheap ARC Raiders Blueprints from Verified Sellers on U4N
If you find yourself in need of resources or blueprints to enhance your ARC Raiders experience, it’s worth considering buying cheap ARC Raiders blueprints from verified sellers on U4N. These blueprints can help you craft powerful equipment and unlock additional functionalities in the game, improving your overall gameplay experience. Make sure to check reviews and confirm that the sellers are verified to ensure a safe transaction.
The Buried City Residential Master Key is a key item for unlocking certain doors in the Buried City, leading to hidden loot, new areas, and important resources. Acquiring and using this key efficiently will help you progress through the game and maximize your rewards. Make sure to keep an eye on scavenging opportunities and quest rewards to obtain it, and always explore the Buried City thoroughly to take full advantage of what the key unlocks.
By understanding the key’s value and function, you'll be better prepared to tackle the challenges of the Buried City and reap the benefits of your hard work and exploration.
Ultimate Guide: Arc Raiders Door Blocker: How to get and best use
How to Use the Buried City Residential Master Key in ARC Raiders
FrostRogue7
- Начинающий
starsmart1512a
Re: How to Use the Buried City Residential Master Key in ARC Raiders
Information shows that BBW sex dolls made of TPE material (mostly manufactured in China) typically have large breasts. A 25-kilogram doll is usually less than 140 centimeters tall.
The Chanakyapuri Escorts service proves to be very meticulous there. The presentation and communication of Escorts in Chanakyapuri are done very well and the interaction is also done respectfully. The trusted Call Girls in Chanakyapuri, is consistent in providing a calm atmosphere and quality.
