EZNPC Why Betrayers Husks Farming Is the Fastest Belial Route
Larry
#1 Сообщение Larry »
Farm Betrayer's Husks fast in Diablo IV by chaining Greater Lair Bosses on Torment 2+ for frequent Mini Belial ambushes, then use them to summon Belial in the Palace of the Deceiver for top uniques.
If you're in the endgame loop and you've ever opened your stash only to realise you're missing the one mat that gates everything, you already get why Betrayer's Husks matter. No Husks, no Belial summons, no Palace of the Deceiver runs, and no shot at those chunky hoards that can spit out Ancestral and Mythic uniques. The quickest way to stop spinning your wheels is to treat this like a proper farm route: push difficulty to Torment 2 or higher, then stick with it. Anything under that feels like you're doing the same work for less. If you're trying to keep your runs tight and avoid downtime, some players even top up missing bits through marketplaces like EZNPC, which is handy when you're one craft away from another boss chain and don't want to log off short.
The Boss Loop That Actually Pays
The core loop is simple, but it's got a twist people forget: chain Initiate Lair Bosses into Greater Lair Bosses, then pay attention after the kill. When you pop the hoard chest, there's a chance you get jumped by a Mini Belial ambush. It doesn't show every time, but when it does, it's the whole point of the grind. Drop him fast and you'll usually see an extra 2 to 4 Husks on the ground. That's the difference between a "fine" run and a run that actually moves your stack. If you've got the better summon mats like Shards of Agony or Pincushioned Dolls, lean into Greater Lair Bosses because the ambush feels more consistent and the rhythm is cleaner.
Speed Beats Everything
You don't need a perfect build, but you do need pace. If your boss kills are taking two or three minutes, the farm starts to feel rough fast. You want that under-a-minute vibe: Rogues who can keep traps rolling, Sorcs that can just keep orbs flying, anything that deletes a health bar before the fight turns into a jog around the arena. Pick locations that don't punish travel, too. Long rides and awkward layouts are where your session dies. If you can run as a group, do it. More bodies means fewer mistakes when the ambush hits, faster resets, and less time wasted reloading your flow.
Side Income Without Losing Focus
While you're looping bosses, keep one eye on the Tree of Whispers. Whisper Caches are low effort and they add up, especially if you're already near the objectives. Grab them, dump them, get back to the loop. Treasure Goblins are fun when they appear, but chasing them is a trap. You'll sprint across a zone for nothing, then wonder why you're still short on Husks. A good session is about staying in motion: 20 to 30 minutes of straight boss rushing, minimal town time, and no "maybe this will pay off" detours.
Turning Husks Into Real Attempts
Once your Husk count starts climbing, don't blow it all in one messy set of summons. Plan a clean chain, bring enough mats to stay in the instance loop, and make sure your build can handle the Mini Belial surprise without falling apart. That's when the grind feels fair, because every few runs you're buying another real shot at the loot you're chasing. And if you're trying to keep that momentum going between farming sessions, it can help to prep resources like Diablo 4 Gold so you're not stuck pausing your route just to cover repairs, crafting, or last-minute upgrades mid-cycle.
Mythic Prankster Dungeon Carry Run * 10 times for Sale
