EZNPC How to Get Professor s Research in Pokemon TCG Pocket
Larry
#1 Сообщение Larry »
Professor's Research A4b is Pokémon TCG Pocket's go-to draw Supporter, letting you pull 2 cards fast for smoother starts, better combos, and stronger ranked deck consistency.
If you've played more than a few serious matches in Pokémon TCG Pocket, you've probably reached the same point as everyone else: Professor's Research isn't optional. It's just part of deckbuilding now. The A4b 373 version from Deluxe Pack ex, the one with the familiar Professor Oak art, does one very simple thing. You draw two cards. That's it. No trick, no setup, no awkward condition. And weirdly, that's exactly why it's so strong. In a format this small and this fast, two extra cards can change your whole opening. A lot of players who shop around for staples, accounts, or game resources on sites like EZNPC usually figure this out pretty quickly once they start testing real ranked lists.
Why the effect matters so much
On paper, drawing two doesn't sound like the kind of effect that should define a meta. In practice, it absolutely does. Pocket runs on speed. You need your Basics early, your evolutions on time, and your energy attachments lined up before the other player gets rolling. Professor's Research helps with all of that without forcing you into some narrow line. It fits aggro, midrange, and slower control shells because every deck wants one thing: to stop missing pieces. You'll notice it most in games where your hand is nearly there but not quite. One copy turns a clunky start into a playable turn. Two copies across a match can be the difference between curving out and doing nothing for two turns.
Pull rates, crafting, and the smart way to get it
Actually obtaining the card is where the frustration kicks in. You can chase it in the Pikachu ex Pack from the Deluxe Pack ex pool, but that's a rough plan if you're counting on luck. The odds aren't kind, and burning packs for one staple usually feels bad. Crafting is the cleaner route. Saving 1,250 Pack Points from A4b boosters is slower at first, sure, but it's reliable. Trading exists too, though it's not exactly cheap. Giving up 25,000 Shinedust and matching the same 2-Star rarity is a big ask for most players. If you're new, the best move is simple: build toward this card early, then stop worrying about it. Once it's in your collection, it tends to stay in every serious list you make.
How it plays in real decks
Most players stick to two copies, and honestly, that's the right call. One copy can show up too late. Two gives you a real chance of seeing it when your opening hand is awkward. In aggressive decks like Suicune ex or Greninja, it helps you find your early board and keep attacking on schedule. In slower builds, it's just as useful because it smooths out those turns where you're digging for Rare Candy, Big Energy, or the one missing evolution. Some people try replacing it with more specialised supporters. That usually lasts a week. Type-based options can be strong in the right spot, but they don't offer the same freedom. Professor's Research works when your hand is bad, when it's average, and even when you just need to press your advantage.
Why players keep coming back to it
The biggest thing this card does is remove wasted turns. That's what people really feel when they talk about consistency. In a 20-card deck, every draw matters more than it would in a larger format, so plain efficiency becomes a huge deal. Tournament results have reflected that for a while now, with top lists repeatedly leaning on this card because it lowers the chance of bricking and keeps your deck moving. Newer players often chase flashy cards first, then realise the boring staple was the one they needed all along. If you're planning to invest in the game for the long run, whether through regular play or by looking into Pokemon TCG Pocket Accounts for a stronger starting point, this is still one of the safest cards to prioritise because it makes nearly everything else in your deck work better.
About us:The Fastest Way to Play Mega Steelix EX in Pokemon TCG Pocket (Turn 2 Strategy Guide)
