EZNPC Arven B2a Tips for Better Item and Tool Search
Larry
#1 Сообщение Larry »
Arven B2a gives Paldean Wonders decks clutch search power, grabbing a useful Item or Pokémon Tool to keep setup smooth and pressure on from the early turns.
Arven B2a has turned into one of those cards people keep arguing about between rounds, and I get why. On paper, it looks shaky. In actual games, it can bail you out of some ugly starts. I've been testing it in lists that need a very specific piece to function, and it feels a bit like shopping for the exact upgrade you're missing, which is probably why it reminds me of sites like EZNPC where players look for useful game items fast. The card itself is simple enough: play it, flip a coin, and you'll pull either a random Item or a random Pokémon Tool from your deck. That's not clean search, sure, but it's still search. And in a setup deck, that matters a lot.
Why the flip isn't as bad as it sounds
A lot of players hear "coin flip" and check out right away. That's fair. Nobody likes losing a turn to bad luck. Still, Arven B2a isn't really asking you to gamble on a good result and a dead result. Both sides can help if your list is built with that in mind. That's the key part people miss. If your deck runs enough live Items and enough useful Tools, the card rarely feels wasted. You won't always hit the exact card you wanted, and yeah, that can be annoying, but you often get something playable. Sometimes that's all you need to keep the turn alive and avoid passing with nothing going on.
Decks that actually want it
This card shines in decks where Tools and setup Items aren't filler, they're part of the engine. Fossil builds are a good example. If you're trying to get a Tool online for pressure or you need an Item to get your board moving, Arven can patch a hand that looked completely stuck a second earlier. I've also liked it in faster lists that don't mind either outcome, because hitting something like a Nest Ball early still changes the pace of the game. From what I've seen, it works best when your deck has a healthy split of both card types. If your list is mostly Pokémon and only a couple of targets, don't force it. The card won't magically fix bad construction.
Timing matters more than people think
The biggest mistake with Arven B2a is just firing it off because it's there. Early game, it's great when your hand is awkward and you need to start building a board. Mid to late game, though, it can be better as a stabilizer after disruption or a clunky draw turn. You've got to think one turn ahead. Ask what happens if you hit the Item side, and then ask the same for the Tool side. If only one result helps, maybe wait. I also wouldn't overload on copies. Two feels right. Enough to see it now and then, not so many that your hand gets clogged with situational Supporters when you'd rather have raw draw.
Where it steals games
Control matchups are where I've had the most fun with it, honestly. When your opponent is trying to strip your hand down or slow you into a dead turn, any Supporter that reaches straight into the deck has real value. Arven B2a won't make every game smooth, and it definitely won't turn a weak list into a strong one, but in the right shell it gives you lines you wouldn't have otherwise. That's why I wouldn't write it off as a gimmick. If you like flexible builds and don't mind a little variance, it's worth serious testing, especially for players already exploring different Pokemon TCG Pocket Accounts and trying to learn what kinds of decks can squeeze the most out of oddball support cards.
Pokemon TCG Pocket In Game Iteams For Sale:Mega Charizard Y ex-B1a,Mega Venusaur ex-B1a
