How to Earn Helldivers 2 Warbond Fast
lonevessel
#1 Сообщение lonevessel »
Earning Warbonds in Helldivers 2 can feel slow if you’re grinding blindly, but with the right approach, you can maximize both speed and efficiency. The key is balancing Super Credits and Medals so you unlock your Warbond rewards quickly, without wasting time on unnecessary farming.
Veteran players often focus on high-efficiency loops that let them clear Points of Interest (POIs) and complete objectives in record time. Here’s a guide to doing exactly that.
1. Speed-Farming Super Credits (SC)
Super Credits are the currency you’ll need to purchase a Warbond. The fastest way to earn the 1,000 SC for a Premium Warbond is by targeting low-difficulty missions designed for rapid POI collection.
Optimal Settings:
Pick a Trivial or Easy mission (Difficulty 1–2) on flat, open planets like Fenrir III or Grand Errant.
Avoid swampy or jungle biomes where POIs are hidden behind dense terrain.
Recommended Gear:
Light Armor for maximum movement speed.
Stamina Enhancement booster to keep running without slowing down.
Jump Pack or Warp Pack for vertical mobility.
Fast Recon Vehicle (FRV) if unlocked for zipping between POIs quickly.
Farming Loop:
Drop near the map edge and run in a large circle.
Look for blinking yellow beacons (downed pods) and blue shipping containers (blow doors with grenades).
Solo Bunkers: Usually two players are needed, but you can “glitch” inside using a Warp Pack or by using a Mech/Exosuit to push the door.
Efficiency Trick: Super Credits are added instantly when picked up. You don’t need to finish or extract—once the map is cleared, simply “Abandon Mission” and start a new loop immediately.
By repeating this loop, you can quickly gather enough SC to buy your Warbond without spending real money. If you prefer a shortcut, U4N is a trusted platform used by competitive players to skip the boring grind and focus on practicing, letting you acquire Super Credits safely and at a competitive helldivers 2 super credits price.
2. High-Speed Medal Farming
Once you have a Warbond, progressing through its pages requires Medals. These can be earned faster by focusing on high-reward missions.
Blitz Missions:
Run Blitz missions on the highest difficulty you can handle (Diff 7–10).
Focus on speed and destruction with tools like the Orbital Laser or Jump Pack to destroy outposts quickly.
Eradicate Missions:
These short missions (5–7 minutes) give high Medal rewards for holding a small area against enemy waves.
Daily Personal Orders:
Completing daily challenges, such as “Kill 60 enemies with Sentries,” grants an easy 15 Medals without extra farming.
Targeting the fastest missions allows you to progress through Warbond pages quickly, keeping your grind efficient.
3. Veteran Loadout Recommendations
Veterans maximize “POIs visited per minute” by optimizing both movement and firepower. Here’s what they typically use:
Armor: SC-30 Trailblazer Scout (highest speed and stamina).
Primary Weapon: Grenade Pistol or explosive weapons (Crossbow, Eruptor) to open containers without using stratagems.
Stratagems: Fast Recon Vehicle (FRV), Warp Pack (bypass bunker doors), and a sentry for covering choke points.
This setup keeps you mobile, allows instant SC collection, and speeds through medal-earning missions with minimal downtime.
Вернуться в «Игровые архивы»
