I found U4GM.com while browsing
jornw
#1 Сообщение jornw »
Has anyone else noticed how tough it is to pull the exact cards you need in Pokémon TCG Pocket? I’ve opened tons of packs and still end up missing key pieces for my deck. It started to feel like more luck than strategy, which got frustrating pretty quickly.
That’s when I decided to try buying cards directly instead of relying only on packs. I found U4GM.com while browsing, and it turned out to be a pretty solid option. Instead of wasting time hoping for a rare pull, I could just grab the specific cards I needed and move forward.
What I liked most was how simple the whole process felt. No complicated steps, no confusion—just pick what you need and you’re good to go. It saved me a lot of time, especially since I don’t always have hours to grind.
It also helped me experiment more. Before, I was stuck building decks around whatever cards I happened to get. Now, I can actually try different strategies and see what works best. That made the game a lot more enjoyable for me.
Of course, some people prefer the traditional grind, and that’s totally fine. But if you’re someone who values efficiency or just wants to build a competitive deck faster, this approach makes a lot of sense.
Curious how others feel—do you prefer grinding for packs, or would you rather just get the cards you need right away?
