The Mom Conquest Map in MLB The Show 26 is a special event designed for Mother’s Day. It’s loaded with rewards like packs, Stubs, and exclusive cosmetics, plus the 92 OVR Topps Now Javier Baez (3B, CHC). If you want to collect everything quickly, there’s a smart way to tackle the map without wasting time.
Core Efficiency Strategy
Skip the “Steal Fans” Phase
The “Steal Fans” phase can slow you down. Skipping it doesn’t hurt your progress and lets you capture territories faster.
Focus on Territory First
Grab as many empty spaces as you can in your first few turns. More territories mean more reinforcements (Fans), giving you an advantage for strongholds later.
Simulate Non-Stronghold Games
Only play games against strongholds. For regular territories, use simulation to save time and speed up your conquest.
Build a Strong Path
Don’t spread your Fans thin. Instead, create a single strong path across the map. This helps you reach hidden reward tiles and strongholds quickly.
Mom Conquest Map Rewards
By completing the map, you can earn:
Player Reward: 92 OVR Topps Now Javier Baez (3B, CHC)
Hidden Rewards:
3 The Show Packs
100 Stubs
1 Diamond Duos Pack (1/40k pack)
Cosmetic Items: Mother’s Day Profile Banner, Bat Skin, Stance Socks
Additional Rewards: XP and standard packs
Hidden rewards are scattered across the map. Many are earned just by occupying specific tiles, so plan your route carefully to grab everything.
Step-by-Step for Maximum Speed
Reinforce and Attack
Move your Fans to your front-line territory, then expand outward to capture empty hexes efficiently.
Locate Hidden Hexes
Use visual guides (like showdd.io
) to find the exact tiles for hidden packs. Capturing these early maximizes your rewards.
Surround Strongholds
Before attacking a stronghold, surround it with your territories. This gives you a huge fan advantage, letting you play the game at lower difficulty (Rookie or Veteran) while still winning easily.
Simulate Weak Games
For any non-critical battles, use the simulation option. This saves time and lets you focus on the high-reward strongholds and hidden tiles.
By following these strategies, you can complete the Mom Conquest Map quickly and efficiently, claiming all the packs, cosmetics, and XP without unnecessary delays. Focus on strong paths, skip slow phases, and hit the hidden hexes first—your rewards will pile up in no time.
MLB The Show 26 Mom Conquest Map: Fastest Way to Collect Rewards
lonevessel
