ARC Raiders coins feel tight stocked up on EZNPC rn
Larry
#1 Сообщение Larry »
ARC Raiders coin farming gets faster with 10-minute locker loops and smart extracts. See what to sell first and which upgrades pay off soonest.
Seven dead raids for one flashy PvP clip is a terrible trade if your goal is ARC Raiders coins. If you're trying to figure out how to farm coins fast, think extractor first, fighter second; even players who shop at EZNPC for a boost still need a loop that actually pays. The short version: grab one strong sell item, leave, and pour the money into stash space before anything else.
How to farm ARC Raiders coins without wasting runs
I learned this the hard way after burned through a decent kit chasing a third fight near an industrial POI. The run was already won. I had purple crafting mats, a rare weapon part, and a clean extraction lane, but greed kicked in and I got folded by another squad. Since then, my best coin sessions have been boring on purpose — courier stash, locker cluster, tool carts, then out.
Spaceport and the industrial zones are still the best bet from what I've seen, mostly because the container density is silly. You can clear lockers, pockets, and side rooms in under ten minutes if your loadout has movement, stamina, and stealth instead of wannabe boss-melt DPS. If a legendary trinket or blueprint pops up, no shot I'm staying for bonus loot. I ping extract and leave.
Best coin spending order in ARC Raiders
Here's the thing though: farming faster means nothing if you spend like a maniac between raids. First priority is stash expansion, always, because more slots stop you from dumping good loot, duplicate weapon parts, and Expedition materials just because your inventory is jammed. After that, push Workbench and Gunsmith upgrades, since better crafting opens up stronger sellables and better raid gear at the same time.
Augments come next, but not every augment. Loot speed, movement, stamina, heals, and defib utility are the ones that help with survival, and survival is what turns mediocre loot into actual ARC Raiders coins. Cosmetics can wait. Insurance, beacons, and decoys are worth buying once your core upgrades are rolling, because replacing one lost loadout usually costs more than the tool that would've saved it.
Are bosses or crafting better for ARC Raiders coins?
Honestly, it's a toss-up, and your mileage may vary. Solo, I think crafting wins more often. Ammo bundles and utility items can hand you steady profit if you've already stacked the right materials, especially after a long session where your stash is packed with bits you weren't planning to use. In a coordinated squad, though, elite ARC enemies and bosses start making sense because the parts and blueprints can sell hard or feed expensive crafts.
My repeatable coin loop that actually sticks
1) Enter with a light loadout. 2) Hit a courier path or locker cluster first for guaranteed value. 3) Rotate to a nearby high-tier POI only if gunfire sounds manageable and your team isn't scuffed. 4) Extract the second a jackpot item shows up. That's the bit most guides skip, weirdly enough. Keep a small reserve too; if you later grab ARC Raiders iteams or loot a lucky blueprint, you'll want enough coins ready for stash tabs or a key upgrade instead of scrambling through junk sales. The players who progress fastest usually aren't fragging harder — they're just leaving sooner.
Contatc us:ARC Raiders Sirena Dorata Ship Model Guide: Best Locations, Farming Routes, and Avian Alarm Tips
