Forza Horizon 6 Car Guide: Dodge Charger R/T Location Tips
FrostRogue7
#1 Сообщение FrostRogue7 »
Where to Find the Dodge Charger R/T
The Charger R/T is tucked away behind the clubhouse structures at Naruo Golf Course. The location is a little sneaky, so following the steps below will save you time and frustration.
Step-by-Step Location Guide
Locate Minamino:
Open your map and head northeast of Tokyo to find the Minamino region. It’s the area with rolling hills and winding roads perfect for cruising in a muscle car.
Find the Golf Course:
At the center of Minamino, you’ll see the light-green fairways and sand bunkers of Naruo Golf Course. This is where the Charger is hiding.
Target the Ponds:
Look for a water hazard shaped like a rough figure-eight in the middle of the course. This is your visual marker to line up the next part of your route.
Locate the 365 Store:
From the ponds, travel east toward the main road. You should spot a small convenience store labeled “365.” This store is your clue that you’re very close.
Sneak Behind the Building:
Drive around the right-hand side of the store, as if you were entering the golf course. Make a tight turn to navigate the narrow path between the store building and the fence. Keep an eye on the edge of the path near the golf carts.
Claim the Car:
At the end of this path, tucked behind the clubhouse structures, sits the 1969 Dodge Charger R/T. Simply approach it to add it to your garage.
Dodge Charger R/T Performance Overview
Once in your collection, the Charger offers classic muscle car vibes with balanced stats for both casual cruising and spirited runs:
Speed: 5.1
Offroad: 5.3
Acceleration: 3.6
Launch: 3.5
Handling: 2.5
Braking: 2.4
While it’s not the most agile car in tight corners, its vintage charm and offroad capabilities make it a fun option for exploring Minamino’s open roads and hill climbs.
Final Tips
Approach the narrow path slowly to avoid hitting fences or golf carts, which can block your progress.
Once claimed, experiment with upgrades to boost acceleration and handling, making the Charger more competitive in races or free roam challenges.
Treasure Cars are always worth exploring on foot first—sometimes a shortcut or alternate path makes the approach easier.
The Dodge Charger R/T is a rewarding find for collectors and muscle car enthusiasts alike. Following these steps ensures you won’t miss it while exploring the beautiful Minamino region of Forza Horizon 6 Japan.
