Arc Raiders Heavy Fuze Grenade Trial Guide
BlazeTiger
#1 Сообщение BlazeTiger »
In ARC Raiders, the Heavy Fuze Grenade trial is one of those challenges that looks simple on paper but actually rewards very deliberate positioning and timing. The objective is straightforward: deal as much damage as possible using a single Heavy Fuze Grenade in one run, then successfully extract so the score is recorded.
What makes it interesting is how damage is scored. The Metaforge conversion rate gives 11.5 points per 1 unit of damage, which means every extra hit tick matters. You're not just trying to "explode something"--you're trying to stack as many overlapping damage zones as possible from one blast. That's why tight enemy clustering or multi-part weak points become the core of every high-score strategy.
Understanding the Trial in Practice
Most players fail this trial not because they miss their throw, but because they use the grenade too "cleanly." A single target explosion usually caps out at a low score. The real scoring comes from:
Multi-part enemies (legs, armor plates, cores)
Dense enemy groups
Environmental choke points that force stacking damage
In short: one grenade, but as many damage instances as possible.
Strategy 1: Bastion Core Bombardment (Most Reliable 3-Star Method)
One of the most consistent ways to clear the 3-star threshold is in Stella Montis, targeting a Bastion ARC.
The method works like this:
Break the rear yellow canister to weaken the unit.
Strip the front metal faceplate.
Expose the central core.
Throw the Heavy Fuze Grenade directly into the exposed core.
Because the Bastion's structure is layered, the explosion doesn't just hit one hitbox. It simultaneously damages:
Core
Multiple leg joints
Nearby armor fragments
In practical runs, players report that this setup alone can push you past the required threshold comfortably, as long as the grenade lands inside the exposed center.
Strategy 2: The Shredder Rodeo (Highest Score Potential)
This is the high-risk, high-reward method.
You bring utility tools like barricades, door blockers, and gas mines to funnel multiple Stella Shredders into a confined space. Once they are tightly stacked, you throw a single Heavy Fuze Grenade into the middle.
The damage overlap here is where scores explode. Instead of one target, you're hitting:
Multiple enemy bodies
Overlapping hit zones
Chain reactions from clustered AI movement
Some optimized runs using this method have reached 14,000+ points, mainly because every damage tick multiplies through density rather than raw explosion size.
Strategy 3: Matriarch Feed Technique
The Matriarch offers another angle for players who prefer controlled setups.
The key is to strip armor from the joint areas where the legs connect to the central body. Once the internal structure is exposed, you throw the grenade so it lands inside the central gap rather than on the surface.
This creates multi-zone damage overlap:
Leg joints
Core body section
Internal exposed structure
It's less chaotic than the Shredder method but requires precise positioning.
Strategy 4: Sentinel Turret Shortcut
If you want a low-stress completion, Sentinel turrets are a viable alternative.
By throwing a Heavy Fuze Grenade directly near an active turret, you can trigger stacked damage interactions due to how stationary objects register explosive overlap. While not always the highest ceiling, it can reliably push you over the 3-star threshold with minimal setup.
Critical Rules You Can't Ignore
Two rules define whether your run actually counts:
Single grenade only: The trial evaluates one explosive event, not cumulative damage.
You must extract successfully: If you die, the score does not register, no matter how high the damage was.
This is where many players lose good runs--they focus on damage but forget the extraction phase entirely.
Example Run Breakdown (Realistic Scenario)
A typical successful Bastion run might look like this:
Setup time: 2-3 minutes to locate and expose core
Grenade damage window: single throw
Damage distribution:
Core hit: high multiplier ticks
Legs: secondary splash damage
Armor fragments: minor overlap damage
Even without perfect placement, this often clears the 3-star requirement due to how heavily multi-hit zones scale with the 11.5 points-per-damage conversion.
The Heavy Fuze Grenade trial isn't really about explosives--it's about geometry. Where enemies stand, how their hitboxes overlap, and how efficiently you convert one blast into multiple damage instances.
Once you understand that, the challenge shifts from "hard" to "repeatable."
As players optimize routes and loadouts, many also look into progression shortcuts and blueprint acquisition. In community discussions around optimization and gear progression, topics like U4N, buy arc raiders blueprints safely often come up when discussing faster loadout experimentation and trial preparation.
But ultimately, the cleanest clears still come from understanding enemy structure and timing your single grenade perfectly.
