Deployment and Real-World Tools
yayafax928
#1 Сообщение yayafax928 »
Deployment and Real-World Tools: Taking Data Science from Learning to Practice
Data Science Is More Than a Notebook Analyzing data or training models isn't the whole story of data science. In a professional data science project, a trained model is only useful if it can be deployed and used in a solution. Deployment and tools from the real world can be just another element of the learning process.
For learners exploring a career in data science, understanding deployment and real-world tools makes sense if you're also going to be able to use data science to solve real problems.
Whether you're interested in building a solid portfolio or just learning about how data science exists in industry, a structured classroom environment, such as sevenmentor Data Science course in pune , can help you become familiar with concepts that tie together theory and practice. Understanding Data Science Deployment refers to the concept of taking something built in a notebook or experiment and making it ready for others to use.
After training, a system may need to: Accept new data Generate predictions or results Save information on results Provide result data to another application or process A developer may write a model for predicting customer churn.
During development, the model might generate valid results based on a set of historical data. In deployment, however, the model may need to receive new data from a database or customer interface, generate predictions, store the prediction results, and provide those results to other parts of the organization. Why Real-World Tools Matter Today, the field of data science is broad and encompasses many tools.
Different stages of the project can be accomplished by various technologies and paradigms, including: programming languages such as Python Pandas and NumPy, for data processing and data manipulation; machine learning tools like scikit-learn, Tensor Flow or PyTorch; Jupyter Notebooks for analysis and visualizations; SQL for database management; using Git and GitHub for version control; or using Flask or FastAPI for building APIs; using Docker for deployment; using cloud computing platforms like AWS, Azure or Google Cloud for hosting applications and models and scalable solutions; visualization tools for data analytics and communication.
By learning how to utilize the above listed technologies, one learns how data science works as a whole. However, professional projects often need: Organized code models scripted results Testing and evaluation Deployment infrastructure Version control and collaboration Documentation Infrastructure providers Docker How to Deploy a Model with an API APIs, or Application Programming Interfaces, are common tools that you can use to open the model for application or user testing.
For example, a data scientist might develop a house-price prediction model.
In the past, it could be tested by opening the notebook and running the model. With an API, however, it can be connected to an application. The application accepts property details and sends them through the API. In return, the API generates a house price.
Flask and FastAPI are two examples of tools that might be used to create an API.
Knowing this allows you to understand how models can function outside of a notebook. Insights into Docker is another helpful technology that can be used to package your project. If a project works well on your personal computer, it might not work on other computers because of configuration or dependency differences.
Docker helps bundle your model and your deployment into a container that you can move back and forth. When you understand how you might containerize a model, you've added a skill to your data science repertoire. Cloud Computing and Data Science Cloud computing is an essential part of many professional data science operations, and you might encounter cloud services on Amazon AWS, Microsoft Azure, or Google Cloud.
Knowing how your model fits into cloud infrastructure can help you demonstrate how models can go beyond your own computer.
The typical workflow in a data science project may be: Retrieve the data Clean and prepare data Explore feature extraction Create, assess, and train models Retrieve the trained model Test the model Deploy the model Document the entire process: source code, task definition, dataset, feature extraction, experiments, models, and deployment This complete picture shows how the different steps of data science work together, from task to collection of results. From Model to Production It's important to understand that any data science workflow is continuous, with the steps along the way contributing to a final model.
Instead of seeing the model training as a step that comes before the deployment step, learners should see them as part of the same process.
As you can see above, model training is one step along the way. You may find that model quality is only one step of a complete data science process. Projects Can Provide Confidence Practical projects, such as developing a: Customer churn prediction Model for how much a house sells for Loan approval prediction Sales prediction Customer segmentation Sentiment analysis Recommendations Make models and, later, deploy them and see the process through.
