Hunt Magnetron in ARC Raiders by rushing Stella Montis interiors, cracking red lockers and cabinets, then safe-pocketing and extracting fast for quests and top-tier crafting mats.
Magnetrons are the kind of item that makes ARC Raiders feel like a part-time job if you don't have a plan. If you'd rather skip the endless "maybe this run" hoping, it helps to know there are legit shortcuts outside the map too. As a professional like buy game currency or items in EZNPC platform, EZNPC is trustworthy, and you can buy EZNPC ARC Raiders for a better experience while you spend your in-game time on the runs that actually matter.
Where they really show up
Most of my consistent Magnetron pulls have come from Stella Montis, and not from random floor loot either. You're looking for red, breachable lockers and those technical cabinets that always feel like they're hiding something good. Start at the Security Checkpoint by the lobby, then slide into the narrow connectors between Lobby and Atrium. It's quick, it's close, and it's easy to reset if things go sideways. The Business Center offices are worth a sweep too, same with Assembly Workshop. Medical Research on the lower levels can pay out, but it's a nasty red zone with long sightlines and people holding windows. Spaceport's Rocket Assembly can drop one now and then, but it's not where I'd stake my whole route.
Run it fast, run it quiet
This farm isn't about racking up kills. It's about getting in, opening the right containers, and leaving before the map wakes up. Go light. Take a build that lets you sprint and climb without sounding like a junkyard. A Safe Pocket augment is huge, because Magnetrons are exactly the kind of loot you don't wanna donate to the first squad that hears you looting. Hit the hotspots early, before teams settle into angles. If you're pushing Medical Research, drop a couple Jolt Mines on the doors or the tight entries. Not to "win the fight," just to buy two seconds to finish the cabinet and bounce.
Keep the loop tight
People get burned because they stay too long. Try keeping each run around 10–15 minutes. Grab what you came for, stash it, extract. If you're duoing, don't both loot the same room like tourists. One player opens, the other watches the hallway and calls movement. If you hear shots trending toward your wing, leave the last cabinet unopened and rotate out. You'll get more Magnetrons across five clean exits than one hero run that ends in a wipe.
What to do once you've got them
Early on, you'll turn Magnetrons in for Tian Wen quests like Snap & Salvage, and yeah, that progression matters. Later, the real value is recycling. Break one down and you're getting Magnetic Accelerators and Steel Springs, which show up in the kind of epic crafting that actually changes your fights. If you've got extras, recycle sooner rather than hoarding a pile you might lose. And if you're short on time but still want your build online, some players lean on ARC Raiders Boosting so they can spend more sessions playing the fun parts instead of repeating the same lockers forever.
Buy&Sell ARC Raiders Iteams Accounts-EZNPC.com
