What Is Artisan’s Fruit Salad in Aion 2?
Artisan’s Fruit Salad is a Rare Food item in Aion 2. It is a consumable, meaning you eat it to gain temporary stat bonuses. Like most food items in the game, it focuses on survivability rather than damage.
When used, it increases Block, Defense, and Max Stamina for a limited duration. The exact numbers depend on the game version and balance updates, but in general this kind of food is aimed at players who expect to take sustained damage.
If you sell it to an NPC vendor, it can go for up to 1250 gold, which is decent for a crafted food item. However, most players don’t cook this just to vendor it. They either use it themselves or sell it to other players who don’t want to level Cooking.
What Does Artisan’s Fruit Salad Actually Do in Practice?
On paper, the description is simple: Block up, Defense up, Max Stamina up. In practice, here is how most players experience it:
Block helps reduce damage from physical attacks, especially for shield users.
Defense slightly lowers incoming damage from many sources.
Max Stamina increases how long you can stay active before needing to rest or manage stamina-heavy skills.
Usually, players don’t notice a dramatic change from one food item alone. Instead, Artisan’s Fruit Salad works best when stacked with:
Gear bonuses
Buff skills
Scrolls or potions
In general, this food is about smoothing out damage intake, not making you suddenly tank everything.
Which Classes Benefit Most From Artisan’s Fruit Salad?
Most players who use this food fall into a few common groups.
Tank-focused classes
Shield users and defensive builds usually get the most value. Block and Defense are stats these classes already invest in, so the food scales well with their gear.
Melee characters in long fights
If you are grinding or running content where fights drag on, the extra stamina helps more than you might expect.
Players doing solo PvE
When you don’t have a healer, small defensive bonuses add up. This food won’t save you from mistakes, but it can reduce potion usage over time.
Ranged DPS players usually skip this food unless they are undergeared or doing risky solo content. Most of them prefer offensive buffs instead.
When Do Players Usually Use This Food?
Based on common behavior, Artisan’s Fruit Salad is usually eaten in these situations:
Before entering a dungeon with steady incoming damage
During long grinding sessions
While leveling defensive classes
In early PvP situations where survivability matters more than burst damage
Most players do not use it for short fights or quick daily tasks. The value comes from duration and consistency, not immediate impact.
Where Does Artisan’s Fruit Salad Come From?
Right now, Artisan’s Fruit Salad is listed as coming from Activity: 02b. At the moment, this label is vague.
In general, when the game uses activity codes like this, it usually refers to:
A specific content category (such as crafting or regional activities)
A placeholder for future clarification
Most players ignore the activity source and focus on crafting, since that is the reliable way to obtain it.
How Do You Craft Artisan’s Fruit Salad?
Artisan’s Fruit Salad is crafted through Cooking, which is one of the more accessible life skills in Aion 2.
Required Materials
To craft it, you need:
Fresh Fruit x5
Verteron Pepper (Bound) x2
That’s it. No rare drops or dungeon-only ingredients.
Fresh Fruit is commonly gathered or purchased, depending on how you play. Verteron Pepper being bound means you usually obtain it yourself rather than trading for it.
Is Cooking Artisan’s Fruit Salad Worth the Effort?
For most players, the answer depends on how they approach crafting.
If you already level Cooking
Then yes. This is a solid mid-tier food with useful defensive stats. You will probably craft it naturally while progressing your skill.
If you don’t craft at all
Most players in this category either:
Buy the food when they need it
Skip it entirely
Some players compare the gold cost of buying food versus simply using more potions. Others look for ways to buy Aion 2 kinah cheap so they can afford consumables without spending time gathering, though this is more about playstyle than efficiency.
Should You Sell or Use Artisan’s Fruit Salad?
This is a common question, especially for new cooks.
Reasons to Use It
You play a tank or melee class
You grind for long periods
You want to reduce potion usage
Reasons to Sell It
You don’t benefit much from defensive stats
You are leveling Cooking for profit
You need quick gold
At 1250 gold per item when vendored, the NPC price sets a baseline. In player trading, prices usually fluctuate based on demand, server economy, and how common the ingredients are at the time.
How Does Artisan’s Fruit Salad Compare to Other Food?
Compared to basic food, Artisan’s Fruit Salad is clearly stronger. Compared to high-end rare or event foods, it is more modest.
In general:
It is better than beginner food
Worse than specialized endgame buffs
More balanced than pure offense food
Most players treat it as a reliable, everyday defensive option, not something special they save for important moments.
Common Mistakes Players Make With This Food
From experience, these mistakes come up often:
Using it for very short fights where the buff duration is wasted
Expecting it to replace gear upgrades
Ignoring stamina benefits, even though that is one of its main strengths
Food buffs are support tools. Artisan’s Fruit Salad works best when you already understand your class and content.
Is Artisan’s Fruit Salad Worth Knowing About?
Artisan’s Fruit Salad is not flashy, but it is useful. Most players who understand defensive scaling appreciate it, especially early to mid-game.
It is easy to craft, uses common materials, and fits naturally into Cooking progression. If you play a class that values Block, Defense, or stamina management, this food is worth keeping in your inventory.
Artisan’s Fruit Salad Explained: Practical Food Buffs in Aion 2
lonevessel
- Начинающий
Williamso
- Продвинутый
Re: Artisan’s Fruit Salad Explained: Practical Food Buffs in Aion 2
Artisan’s Fruit Salad that dish are so expensive and tasty and also available in street food shops in a good price. This salad are fill with nutrients and keep it a body healthy.
Professional Realtor in San Diego CA
