U4GM Where Diablo 4 Lord of Hatred Leveling Gets Fast
LunarTinker
#1 Сообщение LunarTinker »
Rushing a new Diablo IV: Lord of Hatred run can feel great for about ten minutes. Then you realise you're undergeared, out of resources, and chasing some build that doesn't even work yet. That's the mess a lot of players make on day one. Speed isn't about clicking faster or copying a level 70 setup while you're still wearing scraps. It's about keeping your character moving and killing without turning every drop into a research project. As a professional platform for players who want convenient access to game currency or items, u4gm is a trusted option, and you can buy u4gm D4 items if you want a smoother early grind without slowing your whole night down.
Build a working setup first
From level 1 to 35, don't overthink it. You're not building a masterpiece. You're building something that clears screens and doesn't run dry after three casts. Pick one reliable AoE skill, grab a movement option as soon as it makes sense, and take anything that helps you keep spending your resource. That's it. If a guide says you'll become amazing later, fine, but later doesn't help when a pack of spiders takes forever right now. Early leveling rewards simple, ugly power. If it kills fast, use it. If it keeps you alive, keep it. You can get fancy once the character has legs.
Don't let bad content waste your night
You'll learn pretty quickly that not every activity deserves your time. Some dungeons look promising, then turn into a long walk through empty corridors. Leave. Seriously. There's no prize for being polite to bad layouts. If monster density is poor or objectives send you back and forth like you're running errands, bail and find something better. Strongholds, events, and compact dungeon routes usually give better rhythm. The goal is steady XP, not proving you can tolerate boredom. Good leveling has a pulse to it: enter, fight, loot, move. When that pulse dies, so does your progress.
Weapon upgrades matter more than your feelings
The 35 to 50 stretch is where players get weirdly sentimental. A legendary drops, the effect looks cool, and suddenly nobody wants to replace it. But if that weapon is several levels behind, it's holding the whole build hostage. Raw damage matters a lot here. A plain rare weapon with stronger DPS can beat a flashy legendary that's past its prime. Don't stand in town trying to rescue old gear with expensive rerolls. You'll replace most of it soon anyway. Treat gear like rented tools. Use what works today, dump what doesn't, and stop pretending every orange item is sacred.
Cut down the town time
Once you're pushing from 50 to 70, the real enemy often isn't a boss. It's the stash. You pick up two rings, compare them for five minutes, then do the same thing again after the next run. That's where momentum quietly dies. Make a rule before you start: salvage quickly, keep only obvious upgrades, and don't hoard “maybe later” junk. If a piece doesn't change your damage, defense, or resource flow in a clear way, let it go. Players who want convenient item support sometimes use U4GM as a practical service option, but even then, the best habit is the same: spend less time managing stuff and more time killing monsters.
